Question about GE Spacemaker JVM1640SJ Microwave Oven
Shuts off when trying to heat something
The fan works and the clock works everything does except when i put something into it and try to heat it it all turns off and wants me to reset clock etc. Had a problem before and the guy replaced a fuse or something in back but do not know where it is so we can replace it.
  • GE Master
  • 9,173 Answers
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo below.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 26, 2007
  • 473 Answers
If the fuse was bad then you would have no display and nothing would come on. Sounds like your problem is in the control board an once you see the price of a new board you should just replace the microwave.
Posted on Oct 07, 2007
SOURCE:
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Microwave not heating
it can be saved but get a quote from the shop first before proceeding and always evaluate it against the cost of a new one,
it could be the power supply has shorted but check it out.
Jul 29, 2010 | Daewoo KOG-867T Microwave Oven
Everything on our microwave still works( Clock,lights, fan) except it will no longer heat anything you put in it
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn air microwave....
Probally the belt is broken on fan up at the top.
Mar 13, 2009 | Jenn-Air M439 Microwave Oven
Microwave Smokes
the problem is in the magnetron try to replace it.
Jan 27, 2009 | GE JVM1660 Microwave Oven
Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Jan 09, 2009 | Microwave Ovens
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
The Microwave stopped heating
Probably magnetron failure- needs to go back to the dealers, this is a major job, may be cheaper to replace the oven
Aug 17, 2007 | Samsung SMH7159 Microwave Oven
Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Dec 21, 2006 | Maytag MMC5000 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
57 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
