not possible , agp should be connected to agp slot while pci should be to pci slot ,motherboard or your video card might be damaged if you try to connect it to the wrong slot
The AGP bus works with a higher frequency, using 66 Mhz instead of 33 Mhz, and uses 64 bits instead of 32 bits. There is no simple way to use an AGP device on a PCI slot, and adapters are not normally available for sale.
There is no way to do that cause the configuration of the slot is different between a pci and a agp slot. If you try and force it in there it will break the slot and possibly the motherboard.
Have a Brother MFC 7420 multi function printer/copier. Keep receiving screen message "Back...
(More)
Have a Brother MFC 7420 multi function printer/copier. Keep receiving screen message "Back Door Open" can you help ?
I have two laptops on one laptop when i plug my pinnacle movie maker into the usb the green light on...
(More)
I have two laptops on one laptop when i plug my pinnacle movie maker into the usb the green light on the pinnacle turns on but when i plug it into my newer laptop it doesnt turn on ??
Cuando enciendo la computadora , me sale una pantalla az?l con el c?digo p4p8oos-x . No entiendo...
(More)
Cuando enciendo la computadora , me sale una pantalla az?l con el c?digo p4p8oos-x . No entiendo mucho de computadora y no s? qu? significa, solo s? que es algo referente a la tarjeta madre. Pueden decirme de qu? se trata? Gracias
