Question about Sony Ericsson K310i Cellular Phone
Language settings predictive - Sony Ericsson K310i Cellular Phone
My Nokia C3 mobile phone has set itself to Italiano on predictive text, how do I change it back to English?
Just go into setting pick up the language issue and change the language to English. It is very easy. If you don't know which option to check in than check setting option one by one. you should be fine.
Dec 05, 2014 | Nokia C3 Cell Phone
How to turn off predictive text from asus tranformer notebook?
To turn off predictive text, go to Settings - Language and Keyboard - Touch Input - Text Input - Prediction.
Then select On or Off - See more at: http://www.phonetipsandtricks.com/tips/samsung-galaxy-note/turn-off-predictive-text-38/#sthash.MPTR2fvE.dpuf
May 08, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
I cant seem to remove the predictive text from mt text messages.
While writing a message, go to
Option > Predictive Text > Set the Predictive Text to Off.
Or simply
Go to Menu > Tools > Settings > Language > Predictive Text (set it to off)
May 25, 2011 | Nokia N79 Cellular Phone
Current language set in arabic. how to change to english?
Since the phone is in another language distinct from English language, you will have to use the phone symbols as a guide to get to Language settings on your Nokia E72 and change it to English. This is because you won't be able to read or understand what's on the phone menu since its not yet in English language.
Click menu, go to tools. Tools has a spanner symbol. Its the first icon on the second line of your phone menu.
Click settings. Settings, also has a spanner symbol. Its also the first icon on the second line of the Tools menu.
Click General. General is the first on the list under settings.
Click personalization. Personalization is also the first on the list under General. It has a paint symbol/icon with red, green and blue dots.
Scroll down by pressing the down navigation button four (4) times and you will get to language.
Click it and the first option on the list is "Phone language". Press it and you will see a list of your phone languages, scroll to English and select it and that would be all.
Follow the above direction and you will certainly get to English language under the phone language.
Good luck.
Apr 07, 2011 | Nokia E72 Smartphone
I have a nokia e51 i want to make it arabic .... how can i make it..
go to settings menu->language settings->
Language settings
To set the language used on the device display, select Language > Phone
language.
To select the language in which you write notes and messages, select
Language > Writing language.
To select whether to use the predictive text input, select Language >
Predictive text.
Jul 07, 2010 | Nokia E51 Cellular Phone
How do I change the language setting to english on
hello
you can try these steps to change your phone's language
Language settings
Select Menu > Ctrl. panel > Settings and General >
Personalisation > Language.
• Phone language — Set the device language.
• Writing language — Select the language used for writing notes and messages.
• Predictive text — Activate predictive text input.
• Input options — Define the settings for predictive
text input.
May 02, 2010 | Nokia E72 Smartphone
Predictive Text
Open Tools
Open Settings
Open General
Open Personalization
Open Language
Set Predictive Text On
Mar 19, 2009 | Nokia N95 Cellular Phone
Hi i bought a phone which is N82 smart phone, however when i connected to my Tmobile network it is working properly but the only thing is that when someone sends me a text message it is in chinese. So, how...
Here's what your user guide says..
Press , and select Tools > Settings >
General > Personalization.
Language
Changing the settings for the phone language or
writing language affects every application in your
device, and the change remains effective until you
change these settings again.
Phone language — Change the language of the
display text in your device. This also affects the
format used for date and time and the separators
used, for example, in calculations. Automatic
selects the language according to the
information on your SIM card. After you change
the display text language, the device restarts.
Writing language — Change the writing
language. This affects the characters available
when writing text and the predictive text
dictionary used.
Predictive text — Set predictive text input on
or off for all editors in the device. The predictive
text dictionary is not available for all languages.
Good luck. Plz rate this if it helps you. Thank you kindly.
In case you didnt get the userguide I'll add a link for it also...
http://www.phonedog.com/cell-phone-research/nokia-n82_user-manual.aspx
Jan 31, 2009 | Cell Phones
Samsung sgh-e900 txt language will not default to predictive
just go into your msg settings then change the predictive text to english standard.
Jan 30, 2008 | Samsung SGH-E900 Cellular Phone
Sony Ericsson K310i Cellular Phone Logo
22 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
