Question about Frigidaire GLTR1670A Front Load Washer
Frigidaire Front Load Washer
Water is collecting in the front platic rings or bellows of the washer and does not drain out. This is causing black mold or something. I have tried to clean it. how can I get it so the water does not collect in the ring?
  • 209 Answers
Most washer door seals when fitted correctly have drain holes at the bottom that allow water to drain from the rings as you call them, this may not be one of those seals and the problem is annoying but there really is no actual cure as such apart from wiping it out after each wash to check if the door seal does have drain holes but is fitted wrong, look round the inner lip closest to the spinning drum to see if there are any holes, maybe higher up or near the top, if there are then it may be possible the seal was fitted wrong (if its not the factory original) the cure then is to replace the door seal and fit correctly some door seals have a large drain hole that is at the bottom that goes into the bottom of the drum (you can't see the pipe normally) this hole maybe blocked if thats the case try prodding it clear with something that wont damage the rubber (use common sense here) hope i have been of some help
Posted on Oct 07, 2007
SOURCE:
I have a Frigidaire front loading washer that is beginning to smell and I thought I should check the "outlet filter." Well it doesn't appear I have one or hopefully I just can't find it.
It could be where the drain pipe is going into the drain.
A lot of machines drain into the water system are not sealed. (ie pipe just fits in and there is an air gap).
You can get fittings that seal the gap so you dont get smells.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Smell odor from front loading washing machine
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
How do I clean the front loader washing machine to decrease odor and residue buildup?
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!$$%%
Aug 06, 2010 | Frigidaire ATF6000ES Front Load Washer
How do I clean the front seal most efficiently? There is an odor and other junk that really needs cleaning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Musty odor in front load machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%$$
Mar 25, 2010 | Frigidaire ATF6000ES Front Load Washer
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Sep 28, 2009 | LG WM1814CW Front Load Washer
Horrible odor from Frigidaire Affinity ATF6700FS
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%&
Sep 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTR1670A Front Load Washer Logo
108 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
