Question about E-Machines eMachines Desktop PC
My T2542 won't start.
Seemed to be a problem with the power supply so I replaced it. No joy. The power supply fan comes on but nothing else does. No power light on the front but the hard disk light comes on yellow. Then it doesn't shut off. I have to unplug it to shut off the power. Any ideas? Thanks.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
There might be a problem with your mother board, or processor, or both of them.
Posted on Oct 07, 2007
6ya staff
SOURCE:
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Computer does not power up
Probably a dead power-supply.
Take the computer to any computer-store,
so that they can remove it, match it up with a replacement,
and install the replacement power-supply.
Oct 09, 2010 | E-Machines T2542 PC Desktop
Motherboard power
hey, without seeing it its quite hard, if the cpu fan aint running you have either not connected the cpu fan cable up, or connected it to the wrong place,
are you sure you fitted the cpu the correct way round when you removed it,
and depending on the processor in the computer make sure you aint damaged any of the pins etc on the cpu.
if you can supply some pictures or something can probably help you better
May 28, 2010 | E-Machines eMachines Desktop PC
Computer wont boot up
If you have one of those generic motherboards with Intel chipset, socket 478, 2 or 3 PCI slots in a mini ATX form so, don't waste your time and buy a new one. Some time ago I replaced it with a cheap Biostar P4M80-M4 and is much better.
Oct 04, 2009 | E-Machines T2542 CELERON 2.5 GHz 256 MB 40...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Elitegroup P4M800 motherboard problem get power for 1 sec thats it real puzzle!!
You ask for two problems here, but let's talk one by one.
According to your explanation it seems to be bad wall outlet connector, broken power cable and finally a broken Power supply.
You can check first two, but to you can't check Power supply.
The point the status led is off means that the 5V part of the power supply is broken. 12V part is (probably) OK because you have a fan running for short, but it is not important because all power sources of the power supply should work.
Now, the best for you is first to (try) buy a new strong power supply (you said you have more devices in your PC) and try with another power cable connected to another wall outlet.
First you should see if you get a status led ON. If so, than your PC should work.
Second question:
three beeps suggest bad memory (it depends of the BIOS). If you have more then one module, try with one only and then with oders, but only one at time.
Regards.
Mar 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
T2542 Emachine
It's hard to troubleshoot a power supply. They are very dangerous and contain electricity for some time after turned off. If your new one isn't solving your problem it makes me think it's not the power supply unless it's not powerful enough. Try this:
Open your case having your "CPU & HEATSINK" in sight. You can lay your case on its side if its easier to see this. Power up watching only the cpu fan located on or in the attached device over your processor (cpu). If it doesn't turn then that is likely your problem. CPU is overheating which automatically shuts down system. Pls. make sure both 20-24 pin and 4 pin plugs from power supply are tightly plugged in mother board before you start.
If it is working try another power outlet in your house. Sounds odd but is a known issue.
Could be a few more things but these are most common.
Let me know pls. your results.
Jul 19, 2008 | E-Machines eMachines Desktop PC
Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Jul 05, 2008 | E-Machines eMachines Desktop PC
P4vmm2 motherboard wont start
cheak and change ur power supply
Jan 05, 2008 | EliteGroup P4VMM2 Motherboard
E-Machines eMachines Desktop PC Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
