Question about Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB / ATA-133 / OEM / RoHS Compliant / with CA Des (890552605880) Hard Drive
Hard drive i have a hard drive caddy, which is usb.2 inside the caddy i have a maxtor diamond 10 model 6L300RO. i made a silly mistake of putting my laptop adapter in (20v) into the caddy (12v) causing the hard drive to blow, leaving that burning electric smell. The caddy still works, i've tried other Hard drives and they all work. Can my maxtor HDD be fixed? Thanks ILLCAT
    Scholar:
  • 51 Answers
It is possible, maybe. I've done similar and only blew a surface mounted diode on the drive's circuit board. I located a blown drive and took that diode from it, soldered it to the one I blew and it worked.
So yes, if you can do similar to what I've described above.
I have to tell you though, that's a longshot.
**Please repost a comment before giving a rating other than Solved.
Posted on Oct 18, 2007
SOURCE:
Our MAXTOR Onetouch 4 mini is not recognized by computer. Can your software recover the data?
could be several issues to cause this fault, make sure your usb port is usb 2.0, replace the usb cable, take the unit apart and look for loose conections, try the drive in another caddy, or try another drive in the maxtor caddy. You will probably be able to remove the drive from the caddy and connect it into your computer if you have a tower and the correct connections.
May 02, 2011 | Maxtor OneTouch 4 Mini 120GB External USB...
All three lights are flashing
No experience with this model but if you open the enclosure there is a regular hard drive inside. You may be able to fit it inside a pc, or use a hard drive caddy to get at your stuff
Jul 10, 2010 | Maxtor Shared Storage II (S01R320) Hard...
I dropped my Maxtor 3200 Hard Drive. now it makes a soft humm instead of its ususal whir. I checked in my device manager and it gives me a code 10. The Maxtor website says to buy a...
a hard drive is a plate between to feelers. if a feeler is bend it will sound strange. but the problem is unless you know someone who has fixed one of these dont open yourself as you will lose everything on you harddrive if you make a mistake.
Dec 09, 2009 | Maxtor BASICS Personal Storage 3200...
My Device Manager sees my Maxtor Diamond Max 10 Model 6L300R0 hard drive, but my Bios doesn't. I'm using it in a USB configuration. Any suggestions? If my partition is unrecognisable would this cause the...
Yes, If your partition isn't being recognized than windows has no way of reading the information. thats why windows create partitions to determine the amount of space and data being used. it anything try to access it in my computer and see if you can. if you can its possible to get you info, i recommend ananother external to transfer the data to or if its not that much info put it on a flash drive
Jun 17, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Maxtor hard drive needs a chip replacing
Unless you can find the matching chip and are good at soldering these small parts, it can be replaced.
Typically, I would suggest looking for busted harddisks (of the same model) and if their board was still good, just do a direct swap. I did this for a Fireball model HDisk.
Or if their board is busted, you can get the chip from them and, like I said earlier regarding soldering, solder it onto your Hard disks. This is considering that the only part busted was this chip.
Jan 21, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Hard drive
If you can find another working 6L300RO, you can try swapping the logic board from the working drive onto the dead one. Try this if all you want is to recover the data from the dead drive.
Jan 15, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Open Questions:
See all Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB / Questions
Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB / ATA-133 / OEM / RoHS Compliant / with CA Des (890552605880) Hard Drive Logo
150 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
