Question about Insignia IS-LCDTV32 32 in. Television
Connecting with samsung dvd/vcr
Cables - yellow, red and white (2 connections Cables - blue, green and red (2) with an connection that is round. Cables - black and red. VCR/DVD AV1 LINE IN - yellow, white and red. AUDIO OUT (bottom) - Black and Red COMPONENT VIDEO OUT - black, red, and green TV COMPONENT IN - black and red. AV IN - black,red, and blue. *** I have a black circular connection and another strand of yellow - white and red, not connected. What am I doing wrong? Thank-You so much, Dawn
4 Suggested Answers
SOURCE:
  • 52 Answers
SOURCE: hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Posted on Mar 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Posted on Dec 31, 2008
  • 324 Answers
SOURCE: im trying to connect my
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Posted on Feb 18, 2011
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
How can an old vcr analog connect to a new digital tv
Although the TV is digital, the market has not dumped the analog compatibility (yet). You can connect your VCR through the RF input, using channel 2, 3 or 4 (depending on your VCR) to view your video collection. Or, you can connect your VCR by RCA cables to the composite video input. Most TVs now have only 1 or 2 composite inputs (Yellow, White, Red). They are sometimes shared, serving as a component input as well (Green, Blue, Red, White, Red). For these TVs, you will notice a yellow circle or some other marking around the Green connection indicating that it is also a composite input. When connecting to such an input, remember to connect the white (and red if your VCR has one) to the white (again, red applies) to the audio input jacks of this video input. I hope this was of some assistance and not too confusing.
Mar 23, 2010 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
Insignia IS-LCDTV32 32 in. Television Logo
315 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
