Question about Motorola Mobility RAZR V3
ENABLE I WANT TO ENABLE THE INFRARED
  • Anonymous Nov 07, 2007
    Would also like to enable this
Not sure the V3 has IR, well mine doesn't anyway.
Posted on Feb 13, 2008
SOURCE:
Acer 5610z infrared receiver disabled in bios
First, what infrared devices are you trying to use? As I'm sure you know altering the BIOS is like taking a stroll in a minefield, one wrog step and........................Well you know.
Nov 17, 2012 | Acer Aspire 5610z Parts Or Reapir
I don't know how enable infrared port in my pc - ibm thinkpad x 41
By default, currently available ThinkPads come with the external serial port disabled and Infrared enabled on COM1. To use the serial port on COM1 you must either disable infrared or change infrared so that it uses alternate resources. If you are not using infrared for printing or file sharing it is recommended that it be disabled. Here are the steps to follow to enable infrared :
1. Double-click your ThinkPad Features or ThinkPad Configuration icon located in the ThinkPad folder on your desktop.
2. Locate the Infrared button located on the left-hand side of this configuration screen and click it once. (Note: If you hold your mouse pointer over any of the icons in this configuration screen the button will be identified at the bottom in the status window.)
3. Change Infrared from "Disable" to "Enable" and click "OK".
4. Locate the serial port icon and click it once.
5. Select serial port "enable" and insure that the COM PORT setting is "COM 1" and click "OK".
6. Shut down and restart the computer.
Jan 19, 2010 | IBM ThinkPad X41 Notebook
My dell D505 turned itself and will not turn back on power light flashes but thats it power supply is fine
  1. Locate Fast IR under Onboard Devices.
NOTE: Ensure that the COM port that you select is different from the COM port assigned to the serial connector.
  1. Press <Enter>.
  2. Use the arrow keys to select the infrared COM port setting.
  3. Press <Enter>.
  4. Follow the instructions on the screen.
After you enable the infrared sensor, you can use it to establish a link to an infrared device. To set up and use an infrared device, see the infrared device documentation and the Windows XP Help and Support Center
http://support.dell.com/support/edocs/systems/latd620/en/UG/setup.htm#wp1112328
Dec 26, 2009 | Dell Latitude D505 Notebook
How do I activate my infrared port ?
Most often, this can be done in the BIOS. Restart the computer and press the key as shown on the enter to enter Setup. This can be F2, DEL or some other key. Once in the BIOS, browse to the categories, mostly under wireless or integrated devices, and look for an entry for Infrared (IR). From there, enable it, save your changes and exit the BIOS.
Oct 15, 2009 | Dell Latitude D600 Notebook
My dell latitude d610 cannot access an infrared connection. please help me.
You need to enable IR in the BIOS.
When the laptop boots, press F2 to go into setup.
Within there you can enable the Infra Red.
Jun 07, 2009 | Dell Latitude D600 Notebook
How to activate the infrared on my laptop
hi have you checked that your unit has an ir device fitted if so you can enable this in the bios if not there shoud be a socket on the motherboard for fitting one you havent given any model details ??
Jun 08, 2008 | Toshiba Computers & Internet
Infrared wont pickup my mobile phone nokia
Click HERE to go to HP to download your wireless drivers. Select your laptop model, then select downloads and drivers and choose your OS to get the drivers.
May 31, 2008 | Compaq Presario 700 470024-192 Notebook
Infrared not working
Make sure the IR is turned on - it may be off by default to conserve battery power. You can get to it via Settings > control panel. It might also be necessary to enable it in BIOS. You should get the "boing" noise when the laptops are in range.
Feb 27, 2008 | Toshiba Satellite A60 Notebook
I can't get my Infrared port to work. What do I need to do?
infrared option shuold be in control panel you will find infraport sideways of pocket pc first try to connect a infra enable mobile device then check it.
Dec 09, 2007 | Acer n30 Pocket PC
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
