Question about Intel D915GAGLK (MB77IN91GAGK) Motherboard
Hdd damage and possible cause
I wrote earlier about my hdd not working even when transfered to another pc. On investigation the western digital 40gig hdd's pcb had blown the quad flat-pack ic was completely destroyed! this was the master drive. the serial ata 120gig was the slave - no obvious damage but again no 'noise' when switched on and is not recognised onany other pc. also found the video card (nforce) appears u/s again when placed in another 'working' pc tried a second card - doesn't work either. when the pc is switched on there is no speaker sound the processor and all system fans are ok. the cd,dvd,tape and floppy devices 'switch on'but now i'm reluctant to try another hdd or graphics card in case the mother board is at fault - could this be the case? could a surge have done this damage or is there a problem with the board that could cause this sort of thing? as i wrote before the mother board was one suggested along with the amd processor to 'overclock' ( ran ok for 3yrs) it is a nforce2 ultra400 deluxe ltd., has anyone had these sorts of problems with this mother board or overclocking? as I said before it's ran ok for 3yrs no probs then on one day booted up really slow,hung on the memory check. help111
  • 80 Answers
Have you check the voltage output of your power supply. HDD's are not that easily damaged, unless it is supplied by a wrong input voltage...
hope this helps...
Posted on Mar 06, 2009
  • 102 Answers
Like you suggested, a surge could have damaged the hardware. Did you have an electrical storm recently?
Posted on Oct 06, 2007
SOURCE:
How to recover data from a broken Western Digital My Book Essential
Remove the HDD inside the case,If the HDD inside is working, remove data with a usb to IDE/SATA Adapter. If the HDD is damaged, which is likely, It ,most likely, can be read, but I don't think you are going to like the bill for that service.
Dec 19, 2012 | Western Digital My Book Essential 1TB...
One short beep one long beep coming from hard drive
..as i know when HDD start beeping ( internal or portable ) that indicate problem with the Hard Drive (HDD)..so nothing you can do it by your self ..
..if the HDD is under warranty from factory you may take it to the store that you buy or nearest Western Digital distributor to claim the warranty...but if it doesn't in warranty..that's mean a problem why?
because if HDD start beeping like you have, the possibility to make it work again is almost impossible that mean you maybe lost the data that you save in this HDD..
Sep 01, 2012 | Western Digital Caviar Computers &...
Hello, hard drive is not visible in the physical drive list. I was using my External HDD for almost 2months (500GB Western Digital). Suddenly the Drive missing. So followed my friends guide to get...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Sep 16, 2010 | Western Digital 320GB MyBook External USB...
My Western Digital USB 160 GB HDD when connected to my PC shows it detected external hdd but the disk is not displaying in MY Computer. I hope there is no problem with the USB port as my printer is...
In that case it's most likely that the hard disk inside has died. Last hope attempt: take it out of the case and plug it in directly to the motherboard. If even then it's not recognized then it's truly dead and all your data has been lost.
Aug 04, 2010 | Western Digital Passport 120GB External...
We purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
Mar 19, 2010 | Western Digital My Book Essential Edition...
My Western Digital MyBook turns on but pc doesnt recognize it!
Have you tried it on another machine?
When you eject your usb devices are you using the proper methods?
Hope this helps.
Nov 07, 2009 | Western Digital 250GB MyBook External USB...
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
BSOD on DEll Inspiron 1521
It could be the memory. Try swapping / reseating them.
BSODS are always fun to diagnose.
When you get it you should receive an 0x000000 etc.
Can you check which one you're receiving?
Jun 15, 2009 | Dell Inspiron 1521 Notebook
Hard Disk Drive
Tell me, what OS do you have?
Sep 06, 2007 | Compaq S5322CC (DT147AR) PC Desktop
Intel D915GAGLK (MB77IN91GAGK) Motherboard Logo
348 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
