Question about Ricoh Aficio Mp C2550 Copier
Purchase fuser unit Ricoh aficio mp c2550
Do you know where can I purchase a fuser unit for an ricoh aficio mp c2550 unit
  • 68 Answers
Precisionroller.com search for Ricoh then model # then fused parts, buy heat roller pressure roller cleaning rollers etc and rebuild the unit a new unit can be upwards of a $1000.00
Posted on Dec 07, 2014
  • Ricoh Expert
  • 422 Answers
Any Ricoh dealer, big $$$
Posted on Nov 18, 2013
3 Suggested Answers
SOURCE:
  • 86 Answers
SOURCE: Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
SOURCE: Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Posted on Feb 23, 2009
How to reset error sc 582
sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
Jan 02, 2015 | Ricoh Aficio MP-C4000
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Ricoh mp c3000 colored copies are double print
Could be drum units there are 4 drums or fuser assy. since you said color only I said drum unit try scanning a single color see which one does it . Will need to call a copier company or go online and buy a whole photoconductor . You will need to know how to initialize unit before you put it in.
Jan 14, 2014 | Ricoh Aficio 1018 Printer
Hy how are u.i hav a problem with ricoh mp c3501 copy machine.its showing error at screen SC582 if any body know about this error how to soulv it so plz help me am waiting.
Mr Aziz, the machine tell you the termistor had to be replaced located at the back of the fuser unit.After replaced it ,you have to reset the maschine in SP mode.....good day
Sep 01, 2013 | Ricoh Aficio MP C3501 Multifunction Color...
Part Number for RICOH Aficio 1022
The fuser part number for a aficio MPC 3000 isB2374053 USA
and B2374054 for EU
Jun 01, 2009 | Ricoh Aficio AP2000 Laser Printer
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Apr 10, 2009 | Ricoh Aficio 2015 Copier
B237 4054 (Europe)
Feb 23, 2009 | Ricoh Aficio AP2000 Laser Printer
Jul 06, 2008 | Ricoh Aficio AP2000 Laser Printer
Ricoh Aficio Mp C2550 Copier Logo
188 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
