Question about Sanyo DS24425 24" TV
Arcing blue sparks internally
Hello,I have a problem with my grandmother's tv.Sanyo DS 24425, started arcing blue sparks in the circuit board between what looks like a capacitor (grey w/ 2 red & 1 green stripe)to an picture adjuster with several wires and 2 adjustment knobs on it marked focus and screen. Where the capacitor(?) attaches to board is marked R405 on one end and R407 on the other. There is no picture/image. Any ideas? Repair procedure or cost estimates? Help- Thanks to anyone for their time. Jeff
  • Anonymous Sep 21, 2008
    sanyo ds24425 makes a cracking sound...blue sparks in back of set....could this be a dust problem???the set is 1.5 years old.
  • plushy Oct 17, 2008
    i have the same problem and my tv is one-half years old as well. maybe they should recall this model. seems to be a common thing.
Dust build up?????mine does same thing along with a cracking noise
Posted on Sep 21, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
The thing which you have seen is resistance not the capacitor. whenever that goes hot or arcing it is due to heavy short ckt in tv. as you are not much aware of tv technology please caall skilled person to do it for you. please now do not start again unless it is repaired. otherwise it may be problematic. good luck.
Posted on Oct 07, 2007
SOURCE:
Samsung tv which iv e had about 6yrs .it started sparking at the back and the picture went . Is it worth getting repaired or am best off buying a new tv
Sparks means short circuit to the main board of the TV, I would advise to get a new one also get the wall outlet checked before you install new one get the earthing checked too.
Jan 26, 2018 | Samsung Televison & Video
Why does circuit breaker spark when turned on?
Under most conditions, sparks occur between contacts of switches, circuit breakers, etc. during the split instant between fully closed and fully open positions (these sparks are really refered to as arcs or arcing). This instant is the point when the full pressure of the internal spring-loaded mechanism that is pushing or pulling contacts together or apart; is not yet felt. This pressure is usually felt only in the fully closed or fully open positions.
The brightness and duration of the arc is directly tied to the amount of power is being switched and the condition of the contacts themselves (contacts become pitted and dirty over time and arcing becomes more noticeable). Many larger switches and circuit breakers employ specially engineered arc flash suppression techniques and materials as the intense heat from the arc is destructive to ordinary insulated switch materials. Ordinarily, the arcing should not be visible to the naked eye.
Here\'s a video of an incredible arc at a power switching station when the switch is opened.
Jan 13, 2013 | Electrical Supplies
I have unplugged because of smell and i could hear a crackling noise, i have completely unplugged but smell is getting worse, i the tv is 10 years old
It sounds that there is some arcing takes place inside it. High voltage arcing will produce and Ozone smell. Contact any TV technician. Never use this set at this condition. It might lead to more fault to internal circuit components.
Nov 11, 2012 | Sony KV-32S26 32" TV
Blue flashes from washing machine motor
What is your model number and where is it arcing to? Is it just an internal flash?
Nov 01, 2012 | Washing Machines
Starts well but stops after about 8 to 10 secounds
points? or arcing through leads? Start car in dark with bonet up & listen for arcing spark & look for spark arcing to exhaust manifold etc...
Jun 14, 2012 | 1994 Subaru Legacy Outdoor
No acceleration when i press the pedal,lights on in the dash board.but the engine starts.
Start the vehicle in the dark, at night is easiest, look for arcing (sparking) components- replace those that are arcing.
If nothing is seen- give it a tune up.
Feb 12, 2012 | Cars & Trucks
Arcing around neck board
sounds like bad crt if you saw arc inside glass...no economical fix-replace the monitor
May 30, 2007 | Likom ViewMate LP995 (White) 19 in.CRT...
Arcing inside no picture
Most times arcing like this is from the Horiz. output transformer (flyback). The insulation has a break down and up to 30 KV will find the nearest path to ground. This would require a tech. to repair the unit. This repair will most likely cost around 250.00.
May 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sanyo DS24425 24" TV Logo
103 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
