Question about Electronics - Others
Imation 512mb flash drive
My computer wont recognise flash drive. Windows 2000 installed.
  • 84 Answers
You need a driver for that to work. i think...
Posted on Nov 02, 2007
SOURCE:
Why wont windows recognise my ptontotec tablet?
No drivers installed maybe? Find the Ptontotec website and see if the support page has drivers that need installing to your computer before Windows will recognise your tablety thing
Oct 20, 2014 | ProntoTec 9 Inch Capacitive Touch Screen...
Imation 320gb
If the drive only uses USB to power-up then most likely the internal power board has failed. If it has a external power supply, then you would want to test that using a multimeter to see if it is still outputting power. Alternatively the hard drive itself could have gone bad (when you plug it in to the computer can you hear the hard making repeating clicks - usually in a pattern). If the hard is still good it can extracted from the enclosure and put into a new aftermarket one such as this: 2.5" sata enclosure
Jul 21, 2013 | Computers & Internet
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
My louck flash is formated and now i can not use the space what do i do?
Your Imation Swivel Flash Drive comes formatted and ready to use right out of the box.
If you will be using the drive exclusively with Macintosh computers, do not format the Imation Swivel Flash Drive. The formatting message appears if your Macintosh has not yet been set up to read Windows-formatted files. Refer to your Mac's user manual to learn how to enable Windows file read functionality.
Also, be aware that when you format your Imation Swivel Flash Drive with NTFS, you will not be able to store as much data as your would without formatting. The format file used by NTFS will use some of the available space on the Flash drive - for instance, on a 128MB Imation Swivel Flash Drive, you may lose up to 8MB to the NTFS format files.
How do I format my Imation USB 2.0 Swivel Flash Drive in Windows? Your drive must be set up as a single public partition, since neither Windows Explorer nor the Macintosh OS will recognize a password protected partition.
To format the drive in Windows:
  • Go to My Computer
  • Locate the corresponding drive letter for the Swivel Flash drive (i.e. removable drive F)
  • Right click
  • Choose Format from the menu
A dialog box will come up and allow you to format your Swivel Flash Drive. Depending on your operating system, you can choose to format the drive in FAT, FAT32, or NTFS.
How to I remove or resize a partition on my Imation Swivel Pro Flash Drive? To resize or remove a secure partition, you will need to do the following:
  • Open the Flash Manager software on your hard drive
  • Choose Create a partition
  • Move the slider to zero (0)
Why don't I see a drive letter for my Imation Swivel Flash Drive?
This problem occurs if you map a network drive to the first available drive letter following the drive letters for the local volumes and CD/DVD drives. When you install a new device or volume, a software called Mount Manager tries to assign drive letters to the new volumes. But since the software does not recognize mapped drive letters, it assigns the next available local drive letter to the new device. This causes a collision with the existing mapped network drive.
Since the problem is related to your Microsoft operating system, they are your best source for resolving this issue. For more information, click here.
Dec 05, 2010 | TDK (CD-RW74HSFXS5) Storage Media
Imation USB not reading in My Computer
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Sep 05, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
Im plugging my flash drive into the usb and nothing is coming up. this one works in other computers but not this one
For starters, what is the operating system of this computer?
Windows XP will recognise flash drives, 2000 seems to recognise some but if you have 95, 98 or Me you need to install a driver for the drive. The manufacturer of the drive may not even supply one.
Sep 28, 2008 | Computers & Internet
It's about my Imation CD Burn-R 12x8x32
It's a "standard" CD-writable drive, but Windows 2000 did *NOT* come with any software for writing CDs.
So, buy the "Burning Suite" from 'www.ashampoo.com'.
It works under Windows 2000/XP to allow you to "burn" CDs.
Apr 10, 2008 | Imation Burn-R CD-RW Burner
Electronics - Others Logo
73 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
