Question about Whirlpool GSQ9364H
Will not spin out or drain
The washer will wash and aggitate but will go no further. I have tried turning it to another setting but to no availe. How do I get to belt? Thank you, Margaret Curry
  • yousfan Feb 06, 2009
    My washer washes the clothes but does not spin so the clothes remain soaking wet.
  • 102 Answers
There should be an access panel at the back to change the belt.
Posted on Oct 06, 2007
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
MY WASHER AGGITATES BUT DOESNT DRAIN WATER OR SPIN OUT
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 10, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
The washing machine doesnt aggitate
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | GE WBSR3140DW Top Load Washer
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
My washer machine is not draining, nor spinning, i replaced the timer, lid switch, and the pump, and its still not draining or spinning. it aggitates so theres nothing wrong with the motor, i dont know...
Hello Friend,
your machine is neither Pumping nor spinning, that is why it is unable to drain the water out. In this case you should check the pump. Your washer probably has a frozen pump pulley. If so you need to replace it. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Do get back to us if you need any further assistance.
Thanks
Mar 05, 2010 | Whirlpool LSR7333 Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
