Question about Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range
Kenmore 103.9846860 I need a new thermostat (key #97, part # 231331) for an old kenmore oven. It appears that the oven is now obsolete. Is there any way to repair this oven without the exact part? Thank you!
  • 102 Answers
Any oven thermostat will work. The problem may be that it wont fit in the same mounting hole. A bit of home engineering and resourcefulness will make it work. Remember to measure the temperature and recalibrate the dial after.
Posted on Oct 06, 2007
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Where could I find older model thermostat replacement for Kenmore 2784218590 Model # Thermostat Part # 326542
You're going to be hard pressed to find that exact part. What I would do is start looking into replacing it with a universal thermostat. Here's one that I've used before that usually works with very little modification:
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Give it a shot. What have you got to lose? It's cheaper than buying a new wall oven!
Good luck
Oct 23, 2014 | Ovens
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
Kenmore plt083-2 won't heat above 200 degrees
Please check that model number again. The one you posted comes up as a refrigerator. Look inside the oven door or the lower drawer.
Feb 03, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Wall electric oven gets hotter than the tempature reading on the control dial
If this has a manual turn oven control (not electronic) you will have to replace the oven control thermostat.
First shut the power off to the oven at the main breaker. Remove the screws holding the front control panel in place. Some of the screws are located inside the oven and some are on top of the control panel. Tilt the control panel forward to access the oven thermostat. While holding the new thermostat in your hand transfer each wire the the corresponding numbers on the new thermostat. Unclip the oven sensor from inside the oven and feed it into the control panel area.Remove the screws holding the old thermostat to the control panel and discard old thermostat.
Insert new thermostat into the control panel and screw to panel.
Reinsert the thermostat sensor into the oven cavity and fasten to clips.
Re assemble control panel.
WARNING: make sure that no wires are touching when reassembling.
When everything is back together, turn power back on and test temperature.
Dec 30, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Replacing oven bottom liner for Kenmore oven
about to do the same for a friend - hers has two visible screws through the floor at the back of the oven. the new plate has several additional holes. i have not yet removed the old, but looking at other google entries, i may just need to take out the visible screws.
not sure of the model, but it is a free-standing kenmore gas range.
gary
Apr 09, 2009 | Kenmore Ovens
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range Logo
128 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
