Question about Panasonic CT-32D12D 32" TV
Can't navigate DVD Menus
I've programed my panasonic TV remote for my panasonic DVD player and everything works except navigating the menus. It is suppose to be the vol (r and l) to navigate, but it just changes the volume on the TV. How do I fix this problem?
  • 3130 Answers
SOURCE: Remotes do not work with TV
Have you tried to unplug the set for 24 hours, then try the remote?
Posted on Dec 10, 2006
  • 32 Answers
SOURCE: Double vision-without viewing under the influence
Their are adjustments on the main video board of the projector for alignment of the three LCD screens, But these should only be made by a qualified professional as they can make it worse if done wrong.
Posted on Mar 16, 2008
SOURCE: navigational system
They haven't made a cd for the navi system..They have a unit button on it but isnt compatible for it? That horrible...
Posted on Aug 08, 2008
  • 2071 Answers
SOURCE: Sony Ericsson K510i joystick
This is the common problem of a joystick is need to replaced including the keypad and also clean the board ,so it will works better again.
Hope thismay help you;
Posted on Oct 08, 2008
  • 79 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
  • 129 Answers
SOURCE: Nokia 6500S , phone is very very slow
it seems that your phone and/or storage card memory is full or almost full try to delete some file and free up some space from phone memory once you do that switch off the phone and start it after 2 min.
it will work fine.
Posted on Mar 24, 2009
0 characters
1 Points
G25819TK RCA tv (1991) aux jack problem
Without looking further you may need the Factory remote not all functions may be accessable using a "Universal" Ha,Ha,Ha remote.These Universal remotes have been problems in my line of work for years,Best idea is when you get a new tv pick up a cheap basic functions remote & use it for everday normal Vol./Channel/Power et. & keep the orig.for things the universal won't do
Jul 28, 2013 | RCA Standard (CRT) Televisions
I cannot find picture controls for my tv? No sound controls button either!!
On most TVs, all the picture and sound adjustments are made through on-screen menus. To get to them, you need the original TV remote control (or a compatible replacement) with the proper MENU functions. On some sets there's one main menu to work through, while others have separate buttons for picture and sound control settings.
Some brands and models of TV have a front-panel menu button. Maybe yours does. Sadly, though, many sets now have just a power button and need the remote control for everything else. The biggest trouble I find is that people get used to using the remote that comes with a cable box, satellite receiver or similar device which will turn the TV on and off but that's all. The original remote mysteriously gets lost (I've actually run into people who threw the original control out because they didn't think they needed it), and then you find you can't get at any other TV settings. It's especially annoying if you can't switch to another input, say for a game console or DVD player.
Hopefully, you still have your control. Good luck, and thanks for using Fixya!
Jun 03, 2011 | Zenith Standard (CRT) Televisions
How can i get to the menu without remote on sharp 25L-M100b
The next model, 25M-M100, lets you get to the menu by pressing Channel Up and Channel Down on the TV at the same time. It's worth trying. However, if you hold the buttons for more than 3 seconds, it may go into demo mode instead. Get out of the demo by pressing the Ch up and down buttons again. If this works, use the channel up and down buttons separately to navigate vertical menus and volume up and down to navigate horizontal ones.
Otherwise, you can get an exact replacement remote from: .
I hope this helps.
Dec 04, 2010 | Sharp 25L-M100 25" TV
Can't seem to switch to input with the remote or go to any channel to use my DVD player
Check first if the Remote Control hanset emits infrared rays or not. Infrared rays are invisioblw to us. There is an easy way to check it. if you have a cellphone with camera option, set it to camera mode, and place the remote hanset against its lens about 1 feet away or so, and press each button on the remote control. You can see the infrared indication on the screen of your cellphone.
If it is Ok, just reset the remote control.
You might need to reset the remote: remove batteries and press the number 1 button for at least 60
seconds. Release the 1 button, replace the batteries, and (if necessary) program the remote again.
Check also for
Something might be between the remote and the remote sensor on the component. Make sure there is a
clear path.
• Maybe the remote isn't aimed directly at the component (DVD, TV, VCR) that you're trying to operate.
• Maybe remote is not in TV Mode. Press the TV button so remote will control TV.
• Maybe batteries in remote are weak, dead, or installed incorrectly. Put new batteries in the remote. (Note,
if you remove the batteries, you may have to reprogram the remote to operate other components.)
How to Use the Remote Control to Complete
the Initial Setup
The technical term is "Navigation"- how you move through the
on-screen menus. The method is the same throughout the menu
screens: highlight your choice and select it.
To highlight a menu item, press the arrow buttons on the remote
to highlight one of the items listed on the screen. Use the up or
down arrow button to move up or down. Use the right or left
arrow button to move right or left.
To select the item that you've highlighted, press OK.
Note: Highlighted means that the menu item stands out from other
menu items on the list (appears darker, brighter, or a different color).
Turn on the TV
Press TV on the remote, or press POWER on the TV's front panel.
Note: Pressing the TV button not only turns on the TV, but puts the remote
into TV mode. "TV mode" means that the buttons on the remote control
operate the TV's functions.
Complete the Initial Setup
The menu system in your TV allows the TV's features to work
properly. The first time you turn on your TV, the SETUP screen
appears with Language highlighted. The default language is
English. To choose another language, press the right arrow
button on the remote.
If these doesn't work, the infrared sensor inside your Tv has got damaged and should be replaced. OK.
Nov 29, 2010 | RCA 27R410T 27" TV
walmart sells a ge universal remote in the check out it is a three in one remote. for five bucks. it does everything i own. except a twenty five year old tv. it will even access the menus on my ac unit.
check it out. you may have to use the manual program mode on the thing but it will probaly work
Mar 12, 2009 | Symphonic Standard (CRT) Televisions
What station do i use to watch the dvd and do i push the up arrow?
You don't use a channel. Make sure your DVD player is hooked up via the AV/Input on the back of the TV. Then, power up the DVD player and put a DVD in it.
On the TV's remote, press the "TV/VCR/SOURCE" Button until you see the DVD output onscreen.
If you do not have the remote control, you must navigate through the menus onscreen by pressing the "menu" button on the front of the TV and changing the input so you can see the DVD.
Take care,
Feb 28, 2009 | Zenith B27A11Z 27" TV
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Partial Cable
The TV is set to antenna mode or over the air mode rather than the cable mode. You should be able to navigate through the menus to change it to cable mode. That should resolve it.
Jun 05, 2008 | Standard (CRT) Televisions
Connecting DVD Player
when you say nothing do you mean the tv wont come on? If the tv is on can you see the words (input, volume bar, menus, etc.) do you hear audio? does the player work on another tv, since you have a sylvania tv, are you using the game button on the top of the remote to switch to the jacks on the front? Good luck :0)
Jul 07, 2007 | Sylvania 6419TC 19" TV
Panasonic CT-32D12D 32" TV Logo
23 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
