Question about Kenmore 99123 Electric Kitchen Range
970-698239 my front right element turns hot as soon as I turn on the breaker...and don't where the swithc to this touch panel...any ideas??? please help
  • 473 Answers
I'm having trouble with the model # provided. If there is no switch directly behind the knob that turns that element on then it has a control board that is most likely behind the back panel about midway down on the left side. If it is this setup you will need to replace the board. If it has a switch directly behind the knob then replace that switch. Make sure unit is not plugged in when looking for or replacing parts.
Posted on Oct 06, 2007
SOURCE:
Kenmore Dryer fuse keeps blowing
Blower housing most likely stopped up with lint. This located behind front panel, lower section.
Sep 23, 2017 | Kenmore Dryers
As soon as I turn on the selector to warm or hot it will trip the breaker but it will run with no heat
It is not uncommon for the heat element to break and short out on a dryer. The element looks like a giant spring and when it breaks it can hang down and touch the frame of the dryer causing a short and tripping the breaker. I suggest you have a service company check it out.
Feb 01, 2016 | Dryers
When I plug in the machine it blows the breaker
dead short in element
call an electrician to check /replace
Dec 13, 2017 | Coffee Makers & Espresso Machines
GE Profile JT912 keep tripping circuit breaker
see this steps and fix it. God bless you
. Top element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#2-2#ixzz2aSmUeYiW
Jul 29, 2013 | GE Profile JT912 Electric Single Oven
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Unit powers up, but trips breaker when I try to heat anything in it
Something is drawing too much current. With the breaker off, check the connections inside the outlet (on the wall). You will have to remove the outlet of course. They should all be tight. It is possible that the outlet is bad - they are cheap, might be a good idea to replace it at that time. Also, check all the connections on the stove, especially at the fuse bar. The breaker box/breaker may also be the problem (loose connections, worn breaker). The element MIGHT be the problem, although they usually pop breakers right away after start up. Also, look for anything touching, including the element wire touching the element casing.
If you have an ohmmeter, you could disconnect the range from the wall and turn on the oven. Measure the resistance across the two power leads (not the neutral in the plug). That will give you an indication of how much power the element draws when it's cold.
where R is the resistance in ohms, V is the voltage (240 V), and I is the current.
Unfortunately, the element may have a resistance that's too low only when it's hot and this might not test that.
Good luck in solving the problem......
Oct 28, 2010 | Ovens
Electric dryer runs , turns but no heat.
You most likely have a bad heating element. When they break, the ends tend to touch the side of the element housing. This causes a short, tripping the breaker. Remove the back panel and replace heating element.
Please rate this solution.
Sep 02, 2009 | Kenmore 73952 Gas Dryer
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Kenmore 99123 Electric Kitchen Range Logo
183 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
