Question about Sony KDF-E55A20 55 in. LCD Television
Regarding problem in sony tv model no. kdf-e60a20
Dear sir, i am facing some strange problem in my tv and want that u should help me out in this matter. when i swith on the tv the green light blinks for almost like 6 times and than it automatically changes its colour to red and blinks for 5 times and it continuous goes on like that
  • Anonymous Nov 02, 2007
    i had this problem... needs new thermo cuppler
  • Anonymous Dec 03, 2007
    I also have the same problem with my television. It blinks green for about 40 times, then, it switches to red and flashes 5 times. How much can the repair cost to replace the thermal fuse?
    Problem Solver:
  • 11 Answers
It works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
  • 43 Answers
I think you may have the wrong diagnosis. If it's blinking 5 times it may be the lamp or lamp driver. If it is blinking 6 times then it's most likely the thermal fuse. You need to double check the blinks. If it's 6 times then have the sirrocco fan replaced on top of the optical block too or the thermal fuse will eventually blow out again. And clean out the dust inside the tv. You need to keep those fans clean for proper cooling inside the tv.
Posted on Jan 06, 2008
6 blinking red light sony kdf-e60a20
Six blinks is a Low B error, B_12V is not supplied, GT board problem.
Aug 23, 2017 | Sony Televison & Video
Tv comes on for 2-5 minutes then goes off
I can help you to solve your Sony KDF-E60A20 tv problem.
Does tv turn back on itself OR standby light start flashing?
If standby light flashing, please count how many times it flashing after three seconds long pause and let me know to diagnose problem.
Thanks.
Dec 04, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My Sony KDF-E60A20 tv is not working this morning my lamp indicator was flashing is this a problem i can fix myself or is a service technician needed?
you can fix by replaced your tv lamp only.mostly lamp number menstion on top side. if not found then tell service center only model number of your tv and get your Lamp. Lamp replacement way menstion in Lamp user manual.
Oct 19, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60 model kdf-e60a20 wega
is the led blinking anything? When was the last time you replaced the lamp? A bad lamp can cause this kind of problem.
Dec 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
61 inch sony LCD projection
Optical block or LVDS cable You need a tech to tell you for sure, have a tech look at it
Sep 30, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf-e60a20 60inch
Yes, it's your thermal switch, had this problem and changed the bulb, no help. Got it checked by tv repair and they changed the switch.
Jan 08, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E55A20 55 in. LCD Television Logo
264 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
