Question about Nikon D50 Digital Camera
D50 wont power up
I have had my Nikon D50 for a year and a half. Recently, while on vacation, I was taking pictures on a full battery and I only took about 30 shots. The next morning, I tried turning on my camera and it appeared that the battery was dead as it wouldn't turn on. Then, I charged the battery for 24 hours and the charger indicated that it was fully charged. When I put the battery in the camera, however, the girl light flashed for a brief second before going away and the camera will not turn on at all. I have tried charging the battery for much longer with no luck. Does anyone have any ideas what is happening. I am hoping to avoid a large camera repair bill but this may be inevitable. Do these batteries go bad, or do you think some internal component is loose or malfunctioning? Thanks for any and all help.
  • Natta Dec 01, 2007
    Downloaded pictures from the camera to my computer, turned the camera off. The next day it wouldn't power up. I tryed reload the battery until "fully charged", but still completely dead...
  • Gary Lewis
    Gary Lewis May 17, 2009
    Changed lenses with the power off. Powered back on and no LCD, or any actions at all. Flash will not pop up, no shutter noise, no auto focus. No top menu, no back menu.
    Did the double green button reset and the hard (hole in the bottom of the camera) resets while both on and off, with and without batteries, with and without SD card and every combination.
    Tried different lenses, also without a lens. Tried with two additional Nikon brand, fully charged batteries, and also with the AC cable.
    Hooked to the Mac, and no "hard drive" icon shows on the desktop.
    This ****** is DEAD.
    I even took off the bottom casing and the back casing. Nothing hanging or loose. The camera was never dropped, never wet, never around static, and was being used inside a hotel room at around 68 dry degrees. Had around 12-14,000 shutter actuations.
    Any thoughts other than the obvious "Send it to Nikon?" It is way out of warranty.
    Thanks.
I have the same problem as well. It is not the battery. I took my camera to the store and had them put a new battery in while there. It never turned on. I really like this camera. I once took about 100 continuous shots. It was great. But now nothing. The D60 camera I have is a higher mega pixel, but does not do alot of things that the D50 does. I wish someone really had the answer as to how to fix it without a high cost.
Posted on Jun 19, 2009
Sounds like something inside is malfunctioning. Batteries do eventually die, but even after years of use, with a 'full' charge as you gave it the camera should at least go on and work for a little while.
Make sure the contact points are not rusted or loose/broken on the battery and in the camera itself. Moisture or humidity may have gotten in and shorted something or caused damage, or it may be something more serious. Either way I'm sorry to say it's probably going to have to go in for repair :(
Posted on Oct 14, 2007
    Problem Solver:
  • 4 Answers
My guess is that it's the battery, not the camera.
I've had a spare battery that wasn't an original Nikon. After 10 months or so it died on me in the same way yours did.
Try getting a new battery and see if the problem persists (I'm sure in the store they'll let you just test it out, before actually buying a new battery).
Posted on Dec 09, 2007
SOURCE:
Nikon D50 Just Quit Taking Pictures!
The imaging board is one of the two boards on the bottom of the camera. however, black images are usually a result of a bad image sensor itself (the 'CCD'), and the cost to replace that is far more than what your camera is now worth (if it is even still available)
Jun 02, 2012 | Nikon D50 Digital Camera with 18-55mm Lens
My Nikon D50 recently started acting up, does not seem to want to take a picture. The camera is less than 3 years old. I love my Nikon and would be lost without it! Please help!
Have you got more than one lens?
If so, I'd see if the problem is present with a different lens.
It could be a connection problem. Try cleaning your lens contacts (on the camera mount and on the lens) to make sure it's not just a bit of oxidation on the contacts causing a bad connection. A t-shirt with a touch of alcohol would probably do it.
I'd do the same thing with the battery contacts (and try a different battery if you have one, in case the battery has a problem).
Have you got another memory card? If so, I'd try a different one to make sure it's not shorting out the camera somewhere. I'd make sure to format it via the camera menus for format, too.
May 27, 2010 | Nikon D50 Digital Camera
Nikon D50 Set Problem - Won't Take Pictures
The F-- error means that the lens is not communicating or has lost communication, with the body. I would first try cleaning the contacts on the lens and body. You might also try another lens. This problem has been known to develop when using a heavier, large lens. It seems like you have had the unit for a number of years. Has this always been an issue?
Hope that helps,
-WN
Aug 31, 2008 | Nikon D50 Digital Camera
Problem with my D50 reading my card
Try resetting all folders in the camera to default setting or erasing any existing folders in the camera, then insert your card.
Oct 27, 2007 | Nikon D50 Digital Camera
Nikon D50
Contact the makers support this is an electronic failure of some kind.
Oct 14, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Shutter
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50
I have this problem too - Nikon have looked at the camera and said I set up a custom setting so that the focus only works when you press the AE/AF Button (!). I also had a problem with the flash not working - its looking like this is a known problem. I think I was sold a Turkey
Apr 19, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
1,318 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
