Question about HP 49g+ Calculator
Display Integer Without Radix Mark
Dear FixYa, How would I display an integer without a radix mark as part of the output of a program? Output I get: Pt # 8. x = 200.0000 y = 300.0000 Output I want: Pt # 8 /* No radix mark */ x = 200.0000 y = 300.0000 Regards, Mark
  • PremiumBlend Oct 07, 2007
    Dear BingoDabbers,
    I entered << CLLCD X INT 1 DISP 2 FREEZE >> where 'X' is an integer. I get an error message. My number format is set to Fix 0.
    Regards,
    Mark
  • 102 Answers
Try x=INT(x)
Posted on Oct 06, 2007
When you turn on the display shows 0,0....i want a decimal instead
To switch the radix mark, turn the calculator off, press and hold the decimal point key, press the ON key, then release both keys.
Jan 03, 2014 | HP 12c Calculator
What is 229,930 rounded to in whole numbers?
That depends on whether the comma is a digit separator or the radix mark. If it's a separator as in the US, the rounded number is 229,930. If it's a radix mark as in most of Europe, the rounded number is 230.
Oct 03, 2013 | The Learning Company Achieve! Math &...
I have a reading of 0,000. that's not good. how do I reset?
What's wrong with it?
If you want to change the number of digits shown after the radix mark, press f followed by the number.
If you want to change the radix mark between the European and US formats, turn the calculator off, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
If you want to see a number other than zero, type it in.
Jan 12, 2012 | HP 12c Calculator
I am using the TI Nspire Cas Graphics Calculator. I have calculated a linear regression that has been copied to f1. When I go to graph the function it is displayed in f1 as 100.x+2000. when the function...
Scientific mode is a display mode. It concerns the display of results. If the number are too small or too large they will be displayed in Scientific mode, because the screen does not have an unlimited number of digit positions.
Regarding the dots. A number followed by a radix mark (decimal mark) is considered to be a floating number, while the same number without a decimal mark is considered an integer (whole number).
The CAS is able to do symbolic and exact calculations, so that distinction between floting and integer numbers is important. Sometimes, to force a result to be displayed in its decimal representation all it takes is to append a decimal mark at the end of an integer.
Hope it answers your queation.
Apr 23, 2011 | Texas Instruments TI-Nspire Graphic...
The display is a comma where it should be a decimal
To switch the radix mark between the European and US modes, press DSP to bring up the display menu. Press the softkey corresponding to the desired radix mark.
Feb 27, 2011 | HP 17bII Calculator
Pressing the . botton will not displays a coma how can I fix that?
You have the radix mark set to comma. To change it to the period, press MODE, then A (FLAGS), then scroll down to "51 Fraction mark." There should be check mark to the left. Press C (CHK) to uncheck it, then press ENTER twice.
Feb 27, 2011 | HP 48gx Calculator
Hi, my 10BII suddenly shows 0,0000000... in the window, and even when I type in new figures they end in ,00000.... The calculator has shut off and when I turn it on again there's the comma. This wasn't...
To change the number of digits displayed after the radix mark (decimal point), press SHIFT DISP and then the number you want.
To switch the radix mark between the US and European modes, press SHIFT ./, (the key in the center of the bottom row).
May 03, 2010 | HP 10bII Calculator
Cannot get rid of comma
It depends on the purpose of your trying to get rid of the comma. If the decimal mark (radix mark) is the comma, you can change it to the dot. If you just do not want to have the 3-digit separator, maybe you should get used to it, or buy another calculator.
To switch the radix (decimal) mark
Turn the calculator off, then press and hold down the [.] (dot) key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
Feb 02, 2010 | HP 12c Calculator
500 x 16 reads 8.000,0 instead of 8,000.00
The calculator has two digit-separation marks: The dot [.] and the comma [,].
By default the decimal (radix) mark is the dot, and the comma serves as a 3-digit separator. In European countries (especially France) the radix mark is the comma and the 3-digit separator is the dot.
To switch the marks:
  1. Turn calculator OFF
  2. Press and HOLD the [.] key while pressing [ON].
Apr 26, 2009 | HP 12c Calculator
Pls. help me
Q.2#  Dim n, sum as Double
Dim i as Integer
n=100
sum=0
for i=1 to n
sum=sum+1/n
next i
Q.3#  Dim sum as Double
sum=0
for i=1 to 99
if i%2 <> 0 then sum=sum+i end if
next i
Sep 16, 2008 | Microsoft AccRepair DS2 2004 for Fr...
HP 49g+ Calculator Logo
mukhtar21 shaikh
mukhtar21 shaikh
