Question about Braun 360° Complete 8985 Electric Shaver
Cleaning problem When the shaver is placed in the base and clean is selected it does not clean...the pump starts whirring, however the cleaning liquid doesnt even get into the hole the shaver sits in and the head remains dry (and not cleaned)...any solutions
  • ranger3 Sep 04, 2008
    The cleaning liquid does not get to the razor head, stays in the cartridge. I have replaced the cartridge etc. The motor is running but liquid does not seave the cartridge.
I had the same problem. I was able to take the cleaning base apart. There are two little latches on the inside that when popped off, allow the cover to come off. It does however take some massaging to remove the cover. Once this is removed, take all the parts off until you get to the electric motor in the base. My suggestion would be to see where the motor attaches to the PCB and use a DMM to measure the voltage across the motor to see where the (+) terminal is when the motor is supposed to be in use. You will notice that the voltage supplied to the motor is approx 12V. This is the same voltage that the cord supplies (DC). Cut the motor free from the board, and directly attach the power cord ends to the motor terminals to see if the motor spins. You might want to take the motor out of the base for this part. What I noticed to the be the problem is there is a fine line between the where the motor is spinning free, when it turns the gears efficiently, and when it is in too far and binds up (which is more than likely the problem you are having now). Adjust the motors position until the gears turn smoothly. Now you can reattach the motor leads to the PCB. REMEMBER to hook them up in the correct holes, otherwise your motor will pump fuild out instead of pumping it back in. If you wish to test this before fully putting it back together, you will notice that there are two posts near to motor that stick up through the PCB. Those are used to measure the amount of fluid in the container. Simply bridge these with some wire or an alegator clip so that the cleaning base will think that were is a full container of fluid.
Posted on Nov 03, 2008
  • 102 Answers
Do you need to replace the liquid?
Posted on Oct 06, 2007
When I put my Braun series 7 in the cleaning station everything is good. It pumps liquid up to clean then it starts to pulse and the vibration shuts the system down. I redo it with the same result.
I wonder if you can charge the shaver with the cord. Or is the battery dead?
Please also check if the blades of the shaving head are pressed on correct. It is the cleaning system, what pumps up the fluid, and after a while is the the shaver that should start pulsing. So it must be an error with the shaver. If the shaver works normal but does not when not in the cleaning station, also check the contacts on the shaver and on the cleaning station.
Jan 10, 2015 | System Clean 6 Braun Syncro Shaver & Renew...
My base does not pump cleaning solution thru the device. I will run the entire process, & there will be clippings in the bottom of the slot where the razor sits. The solution container is full, but...
The pump in the cleaning maching is broken. Pumps are not available seperately. Your only option is to purchase a new cleaning /charging machine. You will find this item for model 7570 available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Mar 06, 2011 | Braun Syncro 7570 Electric Shaver
Just replaced motor assembly now always shows liquid in cleaning station empty even with new cartrige
The motor assembly and the fluid level indicators are completely independent components and any coincidence between the timing of the problem with the cleaning base and your repair of the motor unit is likely pure coincidence. More likely, the cleaning base is at fault and will need replaced.
May 06, 2010 | Braun Activator 8595 Electric Shaver
Braun 8995 clean and charge stand
Use your Warranty. Or you could simply buy another one and return the Lemon one with the reciept for the new one.
Aug 17, 2008 | Braun Syncro 7526 Electric Shaver
Base floods with solution during cleaning cycle
OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
Nov 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Cleaning base
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
Oct 27, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360 Cleaning base
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
Sep 12, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 7526, how to clean without holder?
This is covered in the owner's manual. You can't use the solution, but you can clean the razor without it.
For a quick clean, press the buttons on the sides of the head to release the foil-- but don't remove it. The foil pops up just enough to create openings at the ends of the cutter block. Turn the shaver sideways, hold it over the sink or trash can, and run it for a few seconds. Click the foil back down into place.
For a thorough cleaning, remove the foil and clean the block and foil with a brush (such as the one included with the shaver), then reinstall the foil.
Good luck finding the the base. If you give up the search, I do see that they're available separately for far less than the entire package.
May 09, 2007 | Braun Syncro 7526 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
381 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
