Washing machine starts whirring as though it is starting a cycle, but thats as far as it gets. It whirs and churns as though it is filling, but it does this continually until I have to turn it off incase it burns itself out.
Have drained through emergency pump at bottom, have checked waste pipe, have re-filled with water and tried a fresh cycle, but it just hums and does absolutely nothing. What can be wrong? I've tried the troubleshooting page in the booklet but to no avail.
Paula
Comments:
May 04, 2009
- Hi
thanks for your help. the washing machine isn't filling with water from the main supply. I left the washing machine switched off overnight to try and rectify the problem, but still wouldn't work this morning. the manual said to try and fill the machine through the fabric powder drawer with 2 litres of water, and run the eco cycle at 95C, tried this still nothing happens. the machine just hummed and vibrated but didn't fill, didn;t wash, move or anything. None of the settings work, spin, drain, etc. could this be the same problem as you just described?
thanks
If it hums from start, and it is filling fine from inlet valve, then the problem is usually timer control board or motor control unit board/motor failure.
If it gets stuck on filling forever, check also the pressure switch.
Parts must be tested before replacement.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
- If the machine does not fill and keeps humming from start of the cycle, this can be because of a faulty inlet valve. The valve solenoid has blown and the valve keeps humming and cycle does not proceed.
The inlet valve must be tested befor replacement, as a faulty timer control board will cause the same problem.
I need to replace the door gasket on my Zanussi ZWF12070W washing machine. What's the best way to...
(More)
I need to replace the door gasket on my Zanussi ZWF12070W washing machine. What's the best way to tackle this problem please?
hi my other halfs mums washing machine stopped mid througha cycle and woudlnt drain after trouble...
(More)
HI MY OTHER HALFS MUMS WASHING MACHINE STOPPED MID THROUGHA CYCLE AND WOUDLNT DRAIN AFTER TROUBLE SHOOTING SHE CLEANED FRONT FILTER AND MY OTHER HALF TOOK BACK OFF AND CHECKED PUMP, HE REMOVED A CLEAR BALL AND IT NOW WONT START A CYCLE AT ALL, ITS QUITE NEW AND ONLY JUST OUT OF GUARANTEE ANY HELP WOULD BE GREATFULLY RECEIVED. THANKS DAWN.
