Question about Dryers
Kenmore washer not draining
Hi we have this kenmore washer which was working great. One fine day, i might have overloaded, and eventually it stopped draining the water. But, it continues to do the first round of wash............, and be able to let that water go out. thanks, sakamuri
  • 94 Answers
The pump might be clogged with coins or what not. Check that first.
Posted on Oct 07, 2007
SOURCE:
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Tip
F02 and F09 - valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,...
Hi.
This tip is valid for valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,Fagor, amd more washers built by Whirlpool group.
F02 means that there is a drain problem, and F09 is overflow condition. When you get both error , it is usually because of a faulty pressure switch. Better testing the drain system as described below , before replacing the pressure switch..
To start try clearing the error by disconnecting the power cord or tripping the circuit breaker for five minutes. If you can clear the error, then the problem was just temporary.
The drain pump must be accessed as the drain hose is probably clogged. Also drain pump must be tested and eventually replaced.
If you get the error , but there is no water inside, and drain system is working correctly, then test and eventually replace the water level pressure switch, that determines when to start/stop fillng and drain.
If the drain lines are not clogged, the drain pump can be tested by reading ohms at solenoid (contacts on valve), and by energizing the pump directly.
If the pump is fine, then test the pressure switch by jumping its contacts, and advancing cycle to drain to avoid overfilling.
If you get both the codes, the cause is usually the pressure switch
Since one of the codes is overfilling, check if the inlet valve is opening and closing during the cycle, by observing if water starts and stops flowing into the machine, or by reading volts at inlet valve or at electronic control contacts. If the valve stays open or leaks with no volts from timer, then the valve is faulty. If timer is opening the valve while draining, then the timer board is probably faulty.
If water and sensor are OK, then it can be a problem with wiring or control board. Electronic control board causing this error is not common.
Test all other parts first.
You can find parts and diagrams by entering model number here.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
on Mar 25, 2010 | Washing Machines
I have a series 90 washer and it just stopped and is full of water. It will not power up. where should I start?
must be overload trip. drain water first. reduce load. restart. if doesn't work, check CB or fuse inside the machine
Mar 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Overloaded washer and won't drain
hi,sounds like you have a blocked pump,
Jul 15, 2009 | Kenmore 44042 Front Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Slow leak in our HE 3T Washer?
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
Jun 23, 2007 | Kenmore Elite 45986 Front Load Washer
Tub will not fill with water
That's Great Man. Thank you for letting us know!
Apr 29, 2006 | Kenmore 23822 Top Load Washer
Dryers Logo
106 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
