Question about AOpen AW 850 Sound Card
Sound on my speakers
I had sound on my computer and its stopped. I formatted my computer to try a solution and the sound did not return. All the drivers are installed correctly. I have a cobra AW-850 sound card (AOpen) but I cannot see it in my device manager. I think that my sound card is not detected.
  • Anonymous Oct 07, 2007
    How Can I do that ?
  • 102 Answers
Check that the PCI card has not worked loose on the motherboard.
Posted on Oct 06, 2007
SOURCE:
My sound is real funny like chipmunk sounds
If the pitch of the sound being played by your computer speakers has changed dramatically or songs and videos are playing faster or slower than they typically should be, the problem is with the sound speed on your computer. This could mean a hardware issue with your speakers or sound card or a software issue with the program that you're using to play a digital media file.
Double-check your speaker connections. If one of the audio cables that runs off of your speakers isn't plugged correctly into your computer, this could cause the audio coming from them to speed up or slow down. Make sure all cables are properly connected to their proper inputs and try to play your audio again. Update the driver for your computer's sound card. Go to the website of the company that made your sound card and look for your unit's product page. Under the "Support" section, click on the download link for the latest device driver. Once the file is on your computer, double-click on it to install it. Then restart your computer and try to play your audio again. Make sure you haven't accidentally sped up or slowed down the media file you are trying to play. Many digital media programs like iTunes or Windows Media Player have features that allow you to play a song or video in slow or fast motion. If this becomes accidentally selected, the audio will also be in slow or fast motion. Click "Stop" to stop your media file from playing and then click "Play" again to allow it to play normally. Restart your computer. This will free up system memory when your computer restarts. If your sound was playing too slow or too fast due to an error with not having enough memory to play properly, that error will now be fixed and your sound should return to normal speed. Hope this helps.
Dec 28, 2012 | eMachines Computers & Internet
I purchased theses speakers January, 2011. At first they worked fine. Then I started having problems getting sound out of the left speaker. The sound would return when I plugged and unplugged the speaker...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 04, 2011 | Bose Companion 2 Series II Multimedia...
I have an Acer Aspire (and thats as much as I know) that makes a constant beeping sound ... so fast that I cannot even try to detinguish individual beeps to count them. Sometimes this sound does not happen...
Cardinal Rule 1
Dont use ur expensive computer for Games, go to a galeriya
Cardinal Rule 2
Beeping while playing games is a part of the computer's operation...or it can be part of that game.
Some times ur accessories (like ur printer/USB device/mouse etc) is not connected properly...
if the sound is from the PC's speaker then it can be disabled but u will also not get the games sound.
but if it's from your PC's external speaker then u have to live with it or u can mute ur speakers.
Dec 17, 2009 | Acer Aspire T135 PC Desktop
Speaker power control
If unplugging it did not stop the sound, you have invented a way of producing energy at ZERO cost -- patent the idea, and you could become a billionaire.
Oct 27, 2009 | Logitech X-230 Computer Speakers
Hi, They suddenly stopped working, think I
Try another speaker set.
If this does not fix it, then consider the sound card if it is removeable, get a new one. If it is internal, turn off the sound and install a sound card.
Oct 05, 2009 | Dell A525 Computer Speakers
MacBook sound doesn't work anymore.
My MacBook has been formated wt Microsoft windows XP and the sound is could not work again.
May 30, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Hi... i have a computer but my computer is not have a sound
u must install sound driver and try....once u format the pc ...sound driver will also automatically format their driver...so u have to reinstall the audio driver to retrive the sound again../
Feb 19, 2009 | Audio Players & Recorders
Speakers failed.
Connect headphones to see if you're getting sound from the unit your connected to. If you get sound then the amp fuse might have blown out or IC is gone bad on the unit. If this is a laptop or desktop reboot the system and see if sound returns. Try updating your sound drivers for your PC.
Jul 30, 2008 | Labtec Pulse 485 Computer Speakers
Logitech R-10 speakers sound problem
in control panel, go to hardware and sound, click on realtech audio manager with your logitech speakers plugged in, and then you should be able to chose your speaker configuration. If that doesn't work, try going to sound, and configuring your speaker setup there. Realtech has different settings you can click on, including volume, as well as various equalizer settings which you choose if you want to sound like you are in a sadium, bathtub, etc.
Mar 09, 2008 | Logitech R-10 Computer Speakers
Speakers stopped working
Hello there!
It sound a power adapter failure,
check your speakers for power failure, or bad connections,
check also your sound card, mixer, and drivers.
perhaps if a onboard sound is disable for some reason.
check that too.
Good Luck
Dec 29, 2007 | Harman Kardon HK19.5 Computer Speakers
Open Questions:
AVIRA tEch SuppOrT pHone +++1{8OO}+8O31O69 NumBer u.s.a-24/7 Usa AVIRA USA phone number is ranked #2 out of 2 because 7,728 AVIRA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVIRA USA Tech support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AVIRA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVIRA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVIRA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVIRA USA Calling AVIRA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVIRA USA Tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVIRA USA's Tech support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVIRA USA's phone numbers against each other. Contacting AVIRA USA in General While I8OO8O31O69 is AVIRA USA's #2 most popular phone number, it's not the only way to get a hold of their tech support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVIRA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVIRA USA.
Oct 17, 2019 | Avira Computers & Internet
See all AOpen AW 850 Sound Card Questions
AOpen AW 850 Sound Card Logo
76 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
