Question about Akai PT4799HD Rear Projection Television
Strong red tint with horizontal lines across screen
Hi, I was watching tv and all of a sudden the screen got a strong red tint along with horizontal lines across the screen, I shut off the tv and cable and everything and when I turned the tv off it went to a red line and then shut off, when I turn it back on, it's the same red with horizontal lines. What could this mean?
  • 1 more comment
  • Anonymous Apr 20, 2008
    sony tv model kp57wv600 there are red lines horizon across the screen.
  • torstenson Feb 13, 2009
    I have a RCA 27" television. I was watching tv when the screen was strong with a tint of red and nomatter i do it won't go away
  • Anonymous Mar 30, 2014
    Model 5044 keeps turning off
If you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Posted on Oct 09, 2007
SOURCE:
We have a digital tv but an anologue vcr so we bought a strong srt 5430 so we can record through our vcr but are having trouble conecting the vcr and set top box
You need a cable to go between the yellow (picture), red and white (sound) sockets on the strong to the VCR.
Those cables will connect to one of the VCRs AV inputs. You then need to use the VCR remote control to switch from the now defunct analogue tuner to the Line or AV input. Put your TV on the channel you use to watch video tapes. Switch on the Strong receiver. Do the switch to the Line or AV input on the VCR. When your VCR is on the correct input then you will see the picture from the Strong receiver on the TV. You can confirm it is the correct source by displaying the Strong's EPG.
When you come to make recordings, the Strong will need to be left on the channel that you want to tape. If your TV already has an aerial feed and isn't relying on the strong for its signal then you can watch another channel on TV.
Aug 27, 2014 | Televison & Video
Hj Sony Grand WEGA KF-42SX300 42" LCD TV
Check the options of contrast or tint, if your adjust them to your preferences then maybe it will work, or maybe it is just old. Glad if I helped.
Feb 05, 2014 | Sony Grand WEGA KF-42SX300 42" LCD TV
Red lines across bottom portion of screen
usually strong magnets like those in speakers cause lines on tvs if placed to close to the tv.
so demagnitizing the screen should work .
you may have to take it into a pepair shop to do this.
but if thats not the problem. you moe than likely are seeing a common problem of tv screen burn out. and these new tvs tend to burn out faster than the old ones did.
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Strong red tint and a blurry screen
This is a serviceman only job.  It isn't worth it.  The parts and labor are at least $500.
Sep 15, 2008 | RCA P46924 46" Rear Projection Television
Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Akai PT4799HD Rear Projection Television Logo
645 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
