How to reset ink counter for MG3170, in order to be able to use refilled cartridges?
SOURCE: reset Ink levels for canon mx310
You could just turn the ink refill monitor off.
Open the Windows Start menu, open the "Canon Utilities" folder, open the "My Printer" folder, open "My Printer", click on "Printer Status", go to the "Options" menu, unselect "Enable Status Monitor".
You should be able to tell when your ink is low, because the color will fade.
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
SOURCE: Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
SOURCE: How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
SOURCE: i refill the cartridge pg 510 from a canon mp240 and i don-t know
You can't reset the counter of any Canon Pixma cartridges.You should be to turn off the function on printer for showing the ink level.In most printers this happen with press and hold for 5 seconds the resume button.
