Question about Sony Cyber-Shot DSC-P52 Digital Camera
Cyber-shot 3.2 mega
I have the above camera, the problem i have is that the lent does not open even if the battery is full charged.
  • newfie80 Dec 25, 2007
    have the above camera, the problem i have is that the lent does not open even if the battery is full charged. just keeps telling me to trun off the power n trun it back on but it still dont open
Have the above camera, the problem i have is that the lent does not open even if the battery is full charged. just keeps telling me to trun off the power n trun it back on but it still dont open
Posted on Dec 25, 2007
SOURCE:
The camera won't turn on and I know the battery is fully charged
Fully charged? or reached the correct voltage, without any charge? did you measure the voltage with a multi meter? and was it above the voltage printed on the battery? if it was exact the voltage or even one or 2 tenths of a volt lower, the battery is not good anymore. Then did you check the battery was inserted correct? and are the contacts clean and shiny? no debris in the battery housing? Just to mention some things you could check.
When you close the battery door, does it click? when closing (or opening) the battery door a switch is engaged (disengaged) to tel the logic, if the door is still closed. It will try to protect your memory card by blocking any memory access as soon as the door is opened. (It will not even start the camera as long as the door is open.)
Mar 05, 2015 | Olympus OM-D E-M1 Digital Compact System...
I have cannon digital camera IXUS 255 HS. I
Dear Tejas Belani,
I hope you're still reading this but I had exactly the same problem with the Ixus 255 HS as you describe (full battery - false message - filled battery icon when looking to pictures on the memory card).
After some failed rescue attempts (recharging, completely discharging, 10 second hold of on/off button), I think I finally found it: put a small piece of paper or carton in between the battery opening door and the battery. This pushes the battery a couple of millimeters deeper in the battery bay and ensures a good contact between battery and pins at the other end.
Seems like Canon were a bit cheap on the plastic levers that secure the battery ... or perhaps they erode after some time of usage. This type of camera is often exposed to more aggressive conditions than the bigger, more expensive camera's out there :)
Aug 20, 2013 | Canon Cameras
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
Moultrie camera mfh-dgw 2.1 reads BATTERY LOW but battery has full charge.
1st, unless you have a solar panel on this cam, stay away from rechargeable batteries.When new they will be @100+%, but have to be virtually drained to get to charge back, and then will only charge to about 80%.A solar charger will keep them @ above 80%.
Now, to solve your prob;I have found dirty/corroded contacts;evidence of dampness/corrosion @battery connections to main board; and fireants...they are attracted to electrical and will electricute themselves causing open connections...just a few solutions to ck out.
Feb 28, 2010 | Moultrie MFH-DGS-100 Digital Camera
Sony DSC-S70, battery not charging to a full charge
That battery is not good.if the battery have warranty please give back and get new one. after that the problem continues, The charging control ic of the camera may be damaged
Sep 21, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
They charge gets over very soon,even replaced the batteries
Please provide the correct camera model. If it is the Sony model mentioned then it uses an Infolithium battery pack which is charged in a very different manner then the one detailed above.
If the model is wrong and you have regular NIMh batteries then charge them for atleast 10 hours if using 2100 mah or above
Aug 21, 2009 | Kodak EasyShare Z710 Digital Camera
No lcd display on this cybershot still camera
no lcd display even though the battery is at full charge any suggestions to solve this problem /
Aug 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Olympus stylus 700 all weather
Have you checked the battery. If you have charged it then it may be a bad battery. also if you are in a cold climate try putting the battery in your pocket for a little while. This is what the manual has to say.
Hope I have been of help.
Feb 13, 2008 | Olympus Stylus 700 / 700 Digital Camera
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
61 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
