Question about Kodak EasyShare DX4530 Digital Camera
Rechargable Battery Problem on Kodak DX 4530
I believe my wife some how managed to push the rechargeable Ni-MH Kodak KAA2HR 2100 MAh double battery pack in backwards. This may have blown a fuse inside the camera. When I place the camera into the EasyShare Dock II cradle, the 3 lights on the front of the cradle no longer light in sequence indicating the battery pack is charging. If I put the Lithium CRV3 pack in the camera, it seems to work OK but the Lithiums only make contact on the bottom of the battery compartment. Is there a fuse I could replace to use recharagables?
Inside the battery compartment, on the same side as the battery cover hinge, you will see a small white mechanism. As I understand it, this is a microswitch which recognises when rechargeable batterys are installed. I suspect this may have been damaged. If so, you will need a rock-steady hand and brilliant eyesight to repair it. Even dismantling the camera is a challenge.
Posted on Nov 17, 2007
Can i use a rechargable battery which is rated 750 mAh(1.2v) if the one in the phone is 850 mAh (1.2 v)?
No it would not be advised to go for a lower mAh as your phone would not perform as eficiently and also too I would recommend to replace it with same as qriginal 1.2 v -Ni-MH battery . And you can get any battery from Amazon .Com at avery good price, that is my go to place if I want something specific.
Jun 17, 2014 | Siemens Gigaset S675 1-Line Cordless Phone
Won't use rechargeable batteries
It could be due to the fact that some rechargeable batteries are slightly different shapes and the nobbly bit on the + end doesn't reach far enough in, as it is the case with Maplin AA batteries.
In my case I placed a small drop of solder with a soldering iron on the + nipple and now they reach into any device.
Nov 26, 2009 | Kodak EasyShare C633 Digital Camera
Our 743 came with a photo docking station that would recharge batteres. Is there another way to charge them
Yes you can., You can need to purchase a wall charger for you r NI-Mh battery the model number of charger is kodak K620 for or if you want a travel charger the model number is kodak K640., Or if your battery is special battery of Ni-MH (KAA2HR) make sure that you will purchased kodak K4500 charger., KAA2HR battery will not charge using a regular wall charger., Check first your battery before purchasing the charger
Nov 16, 2009 | Kodak EasyShare C743 Digital Camera
Shutter wont open
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 11, 2009 | Kodak EasyShare C180 Digital Camera
Batteries will not recharge on Kodak EasyShareDX4330 Camera dock seems to be working fine otherwise.
if your are using the ordinary AA rechargeable battery it will not charge., Camera dock will charge only on a 2 Pack AA battery like KAA2HR batteries or the 2 AA battery that attached together (Ni-MH rechargeable battery pack )
What type of battery are using?
try to purchased KAA2HR
Nov 05, 2009 | Kodak EasyShare DX4330 Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
Have a easyshare dx 4530 camera. looking for dock 11 or equivilant?
Since the Kodak EasyShare Camera Dock 2 is no longer available, you can use a KODAK Ni-MH Rapid Battery Charger K4500-PC-C+1 instead.
Item number is 1717610.
You can also use any brand of battery or charger as long as it is Ni-MH.
Jun 27, 2009 | Kodak EasyShare DX4530 Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Sep 08, 2005 | Sony Cyber-Shot DSC-P93 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
137 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
