Question about Logitech diNovo Edge 9676850403 Keyboard
My "4" stopped working
One minute it was working and another minute it just stopped all together. Nothing spilled on my machine or keyboard (I don't even have liquids at my desk). I tried typing the number on the charger and still got nothing. Nothing is "stuck" as far as I can see because my keyboard is clean. Any advice? This has been by far my favorite keyboard and I hate having to use a temporary one.
  • isabellaval Oct 06, 2007
    Nevermind, it's fixed. All I did was switch the orange button on the side of the keyboard off and on and apparently it reset everything and seems to be working fine :)
  • Anonymous Jan 15, 2008
    It stopped working and has yet to start again although I have reset, rebooted and deleted and re-loaded.
    Novelist:
    Scholar:
  • 167 Answers
The ornage switch denotes the multimedia hotkeys being activated. Turnig it off may have solved your problem.
Posted on Oct 11, 2007
SOURCE:
7ujm buttons stopped working
check to see if you spilled liquid on your keyboard. are the keys sticky that is a sure sign of juice of coffee spill
Jul 13, 2013 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
Full glass of water spilled on my iTouch keyboard. Have tried a fan on it for over 24 hrs and still nothing. Can you help?
Unfortunately some things don't mix (like electronics and water). You can try to dry it out more, let it sit upside down. Make sure you take the batteries out if you haven't already. If that doesn't work you will most likely need to replace it.
Apr 26, 2011 | Logitech Cordless iTouch Keyboard/Cordless...
My dell laptop Inspiron fifteen doesn't type any numbers except 5 or 6. I haven't spilled anything on it ... they just stopped working
have u tryed pulling keyboard out to do that take battery out there are 4 screws remove at the top where the power button is that should clip up gently though, if your battery loads in the front you dont need too remove screw on the bottom too get too your keyboard but on the top of the keyboard after you done that remove key board gently look at your cnnections from the thin ribin see if dirty remove to seperate from the clip its atactched and clean put back together if this dont work buy a new keyboard from ebay..
Apr 10, 2011 | Dell 0Y3740 Keyboard
Spilled icetea on to laptop keyboard, will power up but nothing else screen is black. hp nc4200
Ugh, sorry you had the accident, but many a laptop has survived such a spill (or in my case spills) and booted to tell the tale.
I'm assuming you now have the machine powered off, if not shut ot down immediately and do not try to restart it until you have done the following. There is kind of a standard procedure for laptop spills that I will provide you.
The suggestions below assume that your nc4200 is no longer under warranty.
Remove anything attached to the machine, battery, cables, external drives, anything. Using a soft, slightly damp (yes damp - got to remove as much of that sugar as possible) cloth blot any liquid on the machine gently, do not rub.
Tilt the laptop gently from side to side to allow any possible liquid to drain out. Do not shake the laptop. The Place the laptop upside down so that any potential remaining liquid will drain out. Hopefully you did not spill this amount of tea 8^).
Secure a regular hair blow dryer. Set it to low and slowly move it back and forth over the keyboard from about six inches and do the same for the rest of the machine, focusing attention to the openings that it has for ventilation. Do this for about five minutes or so.
Now the hard part: Set aside the machine in a warm (not hot place) and wait (at least four hours and if you can wait overnight, even better).
Try booting it with nothing attached. If it still doesn't boot the problem has gone beyond the keyboard and you'll have to consider having it professionally serviced.
Good Luck and thanks for using Fix Ya
Mikeyaf
Mar 17, 2011 | Computers & Internet
Hi . thy keyboard on my xps 16 stop working ... i havent drop the laptop ,havent spill nothing on the keyboard ...its just stop working ...the backlight is on ,multimedia and touch pad works but nothing on...
csivoka, see the solution posted here: http://www.fixya.com/support/t3265538-laptop_keyboard_not_working
It worked for me. I had the exact same problem, which coincidentally, showed up today.
Jan 17, 2011 | Dell Studio XPS 16 Notebook
Out of nowhere my Emachines laptop keyboard has stopped working
Sounds like it's either the motherboard or you may need a new bezel.
Another solution that may be cheaper would be to reinstall the operating system. Or do a factory image recovery and see if it's a software issue. First check the device manager to see if there is an obvious driver issue. If not try reinstalling Windows 7.
If that doesn't work then replace the bezel.
If that doesn't work then replace the motherboard.
Jul 22, 2010 | E-Machines AAFQ50400000K0 Keyboard
L key stopped working
Hi:
There isn't much to do for your laptop , except to replace the keyboard. They are somewhat fragile, and do often fail. The good news is that they are inexpensive to replace, usually less than $20. Check out your make and model laptop on ebay, and make sure the keyboard looks identical to yours!
Apr 22, 2010 | Medion MD-40954 Notebook
Keyboard Problems
Did it have a liquid spill? If so, remove the keyboard and wash (yes, wash) it. Run it under a warm stream of water (kitchen tap) for a full two minutes. Use a compressor (or a can of air to get out as much water as you can), and put it keys-forward facing a fairly strong fan for 24 hours. Try it again. If no good, replace the keyboard. If no spill, you need a new keyboard.......sorry.
Aug 25, 2009 | Computers & Internet
Spilled water on my toshiba satellite notebook
try : start-control panel -mouse and keyboard, if nothing weird appear,try to reinstall the driver for the keyboard,you'll find it here:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1311513&rpn=PSMA0U&modelFilter=M105-S3002&selCategory=3&selFamily=1073768663&selModel=1311513%7CPSMA0U
If it doesn't work you will have to change the keyboard and hopfully, there is nothing wrong with the motherboard
Jan 01, 2009 | Joy Toshiba M105 S3002 Notebook
Logitech diNovo Edge 9676850403 Keyboard Logo
79 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
