Question about Soyo DYLM1798 Monitor
Soyo Monitor A thin black line has appeared on the monitor about five inches down from top of screen.
5 Suggested Answers
  • 12 Answers
If you have a digital monitor, press the menu button on the front of it and adjust H size and centering.  Failing this, try changing your refresh rate in Display settings>>Settings>>Advanced.  Failing have a bad power supply in your monitor.
Posted on Oct 15, 2007
  • 45 Answers
SOURCE: Thin Green line from top to bottom of screen
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
Posted on Sep 12, 2008
SOURCE: Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Posted on Aug 10, 2009
SOURCE: LCD monitor problem
I have a LCD flat monitor and it has a black vertical band on the right side of the screen about 2 inches wide, which hides some of the texts of the web sites. Unable to fix it with the monitor screen control, the problem is obviously nmore complex. Please help.
Anton G.
Posted on Oct 29, 2009
Mr BrokRench
  • 1623 Answers
SOURCE: a silver dollar size black spot has appeared in
You have dead pixels, rebooting will not help.
Posted on Jul 21, 2011
0 characters
1 Points
Horizontal lines have started appearing, running all he way across the monitor screen....several close together abour 3 inches from the top, and one, sometimes two, about an inch from the bottom... I have...
what you are seeing ithe horizonal sync lines, have you tried to adjust the settings on this monitor, I would try turning down the brightness, and the contrast. There should be a menu button on the monitor to adjust it.
Nov 18, 2010 | Soyo DYLM2286 Monitor
I have a thin black line across my screen half way down
You don't say whether it is a LCD monitor or a CRT one.
CRT Trinitron tubes have two thin black lines, one at about 1/3 height, one at about 2/3. This is normal and nothing to be worried about (sometimes one and more rarely both lines can't be seen).
LCD monitors should NOT have any black lines at all, and if they do it's probably a driver latch circuit gone bad -- and there's not much that can be done in practice, except replace the monitor.
Oct 24, 2009 | Soyo Computer Monitors
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
Computer monitor screen stays black
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computer Monitors
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Soyo DYLM1798 Monitor Logo
56 people viewed this question
Top Soyo Computer Monitors Experts
Govind Deepak Kumar
Govind Deepak Kumar
Jonathon summesfield
Are you a Soyo Computer Monitor Expert? Answer questions, earn points and help others
