Want more rings before answer machine picks up it only rings 3 times , need more rings before answer machine picks up
Since you declined to give the model of your VTech system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
SOURCE: setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
SOURCE: set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
SOURCE: Need more time to pick up phone(disabled)
The phone does not have this facillity.However,switching the answer machine "OFF" allows me to lengthen the ringtone to 16 rings as on the Users Guide.
Many thanks for your interest,
SOURCE: set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
SOURCE: How do you set the number of times the phone rings
Hi kcee
I think I did find the manual here :
http://157.254.235.130/public/347A8329-0001 (Rev. 1 E&S).pdf
and here :
http://phone.manualsonline.com/manuals/mfg/ge_appliances/29827.html
you can find more types here :
http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_answering_machine_product_list.html
You can find General Electric home page here:
http://www.geappliances.com/electronics/
I suggest you contact GE on the link to get the manual and understanding your answer machine with a reply :
http://www.geappliances.com/service_and_support/contact/form_operating.htm
FOR Thomson Consumer Electronics :
you get there homepage here :
http://www.home-electronics.net/
I did try to find the manual for your specific phone, but could only find these answer machines here (previous and next model number) :
http://www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
http://www.home-electronics.net/ge/pc/IB/29869GE2_IB.pdf
source :
http://www.home-electronics.net/ge/pc/user-manuals.asp
on the second manual here on page 9 you find the settings to answer. I think they have used the same shortcuts for these models. They write ;
### This feature is used to set the unit to answer a call after
a specific number of rings.
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET. The unit
announces the rings to answer, then enters the
incoming message length menu.
TOLL SAVER
The toll saver is the final setting in the Rings to Answer..........####
For the GE model you find these features on page 17
One last thing, you can contact Thomson Consumer Electronics for more specific answer or get the manual here :
http://www.home-electronics.net/ge/pc/contact.asp
they have also a phone :
"For customer service assistance, dial 1.800.448.0329. Our hours of operation are Monday thru Friday, 8am to 8pm Eastern, Saturday and Sunday 10am to 7pm Eastern."
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
