Question about LG WM-2277HW Front Load Washer
LG WD 8050 intellowasher Front loader
Machine wont spin and smells like its burning. I took the back off the machine and the belts and rest of equip looks newish...can you show me a pic of what it should look like and a possible soloution to my problem thanks
  • kelley75 Nov 07, 2007
    Hi i brought a new drum spider and a new belt cost about $120.. hubby fitted them and machine runs like a dream.. the smell was fixed while he had the machine apart i washed the drum and any other part that looked yuck.. problem solved ( for now)...Thanks
NOTE: the powder buildup becomes corrosive and weakens the alloy/cast iron spider which leads to breakage.
The repairer/parts suppliers I spok to said this is a known/common issue, and preventable, if the manufacturer doesn't leave pockets in the arms where residue can collect.
Another easy way to try to prevent buildup is by the regular hot wash to try and disolve any collected residue.
Posted on Mar 12, 2008
The shocks/dampers turned out not to be the problem, it was the spider too like kelley75. Turns out the spider is cast iron/alloy, not stainless steel like the drum. This is subject to buildup due to powder residue getting lodged in the pockets in the arms of the spider. Those who aren't familiar, the spider is a three spoke mount that the back of the drum which it is mounted to and has a centre shaft that protrudes the back through the bearing to the rear pulley which the belt connects to and the motor.
Lessons learnt;
a) to minimise the powder residue run a hot wash at least once a month to break down any buildup (i never used too, thinking it not required and better energy efficiency for the environment) or consider liquid, but this may have other drawbacks.
b) it's easy to determine one of the arms on the spider is broken in hindsight without dismanteling it first. From the front of the washer with the door open, reach in with palm up grabbing the top lip of the inner drum, just inside the door rubber and lift forward with not much pressure (about same as opening a car door) and see if you can feel a little movement. Yes the whole outer drum is suspended and will move as much as the door rubber allows. Don't worry if it's not evident straight away, rotate the inner drum one quarter or third, and repeat lift forward motion. Do this 3-4 times, the arms of the spider are aligned with the plastic ridges inside the drum, if one arm is broken you will feel a slight (0.5-1cm) movement at one of the points, and if you continue to rotate and return to the same point where there's movement this is the arm that is broken.
c) A new spider is not expensive approx A$67.00, but the labour to replace it may make it a better investment to buy a new machine, unless you or someone you know is handy and can replace it for you at less cost. (labour quotes I got were $300-400 to diagnose and fix, plus call out if required to come onsite, or bring it into the workshop).
Currently a LG Intellowasher 7kg is about A$599 and in Brisbane you get a $200 rebate on this, so only A$399 to replace with a new unit.
My machine is spinning OK, but it has a terrible smell of rubber? oil? burning?
Last month I rang LG who said I should have been using Scalex (first I heard) to descale the build up, and they sent me a sample.
Well, it helped for a couple of washes, and I bought some more and used it at least 10 times now, but the smell is worse than ever - can't even wear the clothes. So it is time to ring them again.
Posted on Nov 07, 2007
Check your rubber door seal, is there any wear or bit coming off?
Ours just shredded and I originally thought it was the age of rubber or buildup on the inner lip of the door seal. However after replacing (A$31.70) it and doing the first run after it started to rub again leaving rubbings near the bottom of the seal where the previous one shredded!.
Looking further underneath I can see oil/liquid leaking from the two shocks/dampers (A$15.25 each) and visible hairline fractures in the plastic. These retain the drum casing in place and reduces the movement of the drum when rotating/spinning with a load. Excessive movement may cause the drum to rub or catch on the door seal producing the burning rubber smell and possibly destroying it.
I think they have failed due to age and deterioration of the plastic shocks/dampers and when I went to purchase new ones they weren't the same, and I was assured that they were the correct part, maybe the manufacturer has recognised the fault and changed the shock/damper design. I will fit them this weekend.
SOURCE:
I have a lg intellowasher 7kg wd-8015c (front loader), and its not spinning and the clothes come out wet. whats wrong and what parts will i need please
If the washer is not spinning you need to check on the motor, motor capacitor and the power from the program controller unit. If there is no power to the motor then the controller is a suspect.
Please check this link for tips: removing the motor:
Jun 23, 2012 | Washing Machines
Wont spin correctly, burning smell
Sounds like the belt is loose and or worn. Take off the back and inspect the belt.
Nov 30, 2011 | LG WM-2277HW Front Load Washer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Sep 18, 2009 | Washing Machines
Front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Intellowasher WD-12126RD
it is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Feb 15, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,191 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
