Question about Kirby G4 Bagged Upright Vacuum
Kirby G4 will not start
Worked fine the last time I used it but now...nothing when I turn it on. I checked to make sure everything was connected well but still nothing.
  • 357 Answers
I have published an eBay guide...it may be of help to you. Just click on the link to view it.
Marci
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Posted on Oct 16, 2007
  • 102 Answers
Check the mains socket with something else.
Posted on Oct 06, 2007
6ya staff
SOURCE:
Kirby g4 power will not ingage
There could be a few reasons. Try a different power outlet and check the cord and belt. Next there are two safety switches on the Kirby that need to be engaged for the vacuum to start. One is on the mini-emptor to make sure an outer bag is engaged, the second is on the front nozzle to make sure the nozzle or hose is attached. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-755-6586
Jun 06, 2014 | Kirby G4 Bagged Upright Vacuum
Kirby g4 stoped working
cable has shorted out internally, will need new cable
Nov 18, 2012 | Kirby G4 Bagged Upright Vacuum
My Kirby G4 won't turn on. Everything is engaged as I normally do it, nothing is wrong with my power outlet, changed my hepa bag to a brand new one...
It could be a few different things. First make sure the emptor tank on the side of the unit is pushed all the way closest to the unit. ck to see if light comes on (that will tell you if you have power to the unit.) if so It is an internal problem. Or it might be, what is called the power foot switch. It's kinda of like the brain for the kirby there are 3 saftey switches built into it. they must all be working at the same time for the unit to power. If need be take it to a vacuum repair shop one with free estimates. this way they can diog. the problem and give you a repair cost, if need be. Hope this helps.
Nov 13, 2009 | Kirby G4 Bagged Upright Vacuum
My kirby g4 will not turn on. I have checked the fuse and flex, the switch sounds good. pleas advice
ensure the front housing is properly fitted and the bottom of the bag housing that attaches to the machine, if these are not located correctly the safety switches will not allow the vacuum to start.
Could also be the mains cable, any damage may not be visible on the outside.
Or the motor brushes may be worn out, you will need a professional repairer for this.
Oct 05, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 won't start
When putting on belt and brush housing are u makeing sure the switch on the main housing is being engaged when putting on brush housing to main frame of Vacume
Oct 02, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum When in upright position it automatically switches off.
make sure that everything is latched and closed, also make sure it is even on the floor (also "lock" anything that needs to be-i had the same prob, so many things to check!)
May 17, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Vacuum goes on and off while vacuuming
Defiantly sounds like a loose wire, but double check cord ends to make sure they aren't touch when moved from side to side. If not, check inside and see if their are loose connectors to the motor or even a weak switch.
Jun 20, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 plugged????
Take the bag off of the vacuum, remove the paper bag, clean out the bag tube then put back on. Make sure that the tube is broken, it is, replave it.
Dec 29, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
131 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
