-   Dishwasher runs cycle, but there is a pool of water that the bottom. When I hit start and cancel, it drains. Wondering why it doesn't drain during regular cycle since the hoses etc obviously work since it does drain when I start/cancel?-   nitinman123
Mar 10, 2009
-   brand new whirlpool dishwasher, doesn't drain, leaks from bottom of front door when bottom fills up with water.
-   I often have simiar problems. Sometimes, I find water on ceiling tiles downstairs under the dishwasher. I look inside the dishwasher and it has water standing in the bottom. Never spills out onto the floor so far, but how is it getting downstairs? Reply?-   Guest
Aug 26, 2008
Dirty water in the bottom of dishwasher will not go away. Dishwasher runs fine.
-   Guest
May 28, 2008
-   dishwasher does not drain filter clean hoses clear-   Guest
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
My dishwasher isnt draining, but when I rempve the hose from the air gap it drains all the water into a bucket just fine. Im stumped. Checked all the hoses for blockages the air gap is clean. Can anyone help?
I need an instruction manual for Bosch dishwasher any where in Australia Bosch Dishwasher -...
(More)
I need an instruction manual for Bosch dishwasher any where in Australia Bosch Dishwasher - SGS4002AU/20
the water sits in the bottom of the dishwasher and in the drain in the sink. when the water fills up in dishwasher it spills over onto the floor. its a kenmore ultra wash III
Comment by Guest, posted on Jan 08, 2008
washer wont pump out-thre is a clicking sound from the pump housing when the pump runs. On dismantling the pump back plate the green impeller was detached from the driven shaft-on reassembly the pump worked and then the same sound resumed and the pumping stopped.The question is ---should the impeller be attached to the shaftrather than float freely on the lug on the end of the driven shaft
