Question about Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Hi, I am from the UK and hope you can help me with what I can only describe as a mystery! I have been playing my PS3 thru an HDMI cable on my 50" plasma TV for a few months without any problem. All of a sudden a couple of weeks ago....no picture or sound on HDMI channel. TV says 'no signal'. My sky satellite box can play through the HDMI socket on my TV OK so this kinda rules out the TV and the HDMI socket on the TV. HDMI cable has been tested and is OK. I even tried two other HDMI cables without success. So you would think the problem was with the PS3. Nope... I have another PS3 console which I have hooked up to an LCD TV thru an HDMI cable to my LCD TV in another room. This works fine. BUT, when I connect this other PS3 consoleto the Plasma (via HDMI), this doesn't work either! Both PS3 consoles work perfectly on my the LCD TV. Just so you know, my TV is set to HDMI as it always has been. I am currently playing the PS3 thru the regular audio/video cables but when I try to set the PS3 to HDMI on this channel,nothing happens. I've tried everything short of dropping it from a great height so can you guys help me out??? Look forward to hearin' from you. Many thanks. Badgeman!
  • 3 more comments
  • hwach01 Oct 21, 2008
    I have the same problem. I looked into PS3 web site and tried many things and still nothing. please help. the only next step I can think of is to send it in for repair. anyone know how much would it cost to repair HDMI connection?
    Chris
  • TXC1 Dec 05, 2008
    I have exactly the same problem. Works sometimes, play the PS3 with no problems, then the next time I turn on the console, the TV (Samsung) says there is no connection! It's really bizarre. I have tried two different HDMI cables and this doesn't make any difference. Really frustrating.
  • Anonymous Dec 27, 2008
    tryin to hook up my hdmi cord for my ps3, got sound, but no picture..
  • Anonymous Mar 27, 2009
    the exact same its driving me mad it used to play on it now not bothered
  • phealz9234 Apr 23, 2009
    i have the same problem right now it doesnt work for some reason
    New Friend:
I am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
I had a similar problem. Every time I launched a game the screen went black. This was because I went through the automatic HDMI setup, and I guess the TV lied about it's abilities. When I did this manually and selected accepted output signals (i.e. not 1080p, not Full HD) it all worked fine.
Posted on Jan 13, 2009
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Posted on Oct 20, 2007
I dont know if this will work,, but i suggest u to try this,, click the switch button until u hear the second sound,,
Posted on Oct 22, 2008
3 Suggested Answers
SOURCE:
SOURCE: PS3 not working through HDMI cable
Hi Badgeman,
I repair PS3 Consoles and other Video games, It is apparent to me that you have what is ailing many of the PS3 systems, I am finding the HDMI socket is poorly soldered, and not well supported mechanically. I believe your HDMI socket need to be resoldered. Probably on both your PS3 Consoles. This is common. My service in the USA, and I do not believe it is reasonable for me to repair your PS3 since Shipping and all prohibits the service.
www.playstationclinic.com
Posted on Jun 26, 2008
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
Hi. Please help. I'm using sony Bravia klv-s3210,
Change the resolution for the picture to match the resolution from the PS3. It probably will never work as VGA does not support HDMI resolution.
Jul 25, 2017 | Televison & Video
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
HDMI Port
you will have to look at the manual, but sometimes Audio isn't transmitted on HDMI cable,( I know it makes no sense). sometimes you will have to also use the digital optical audio cable, or SPDIF coax didital cable. I had to use the Di
As for your PS3 I had simillar issue, the PS3 doesn't Automattically adjust from analog, to component, to HDMI. If you get a signal thru the Reg RCA plugs, if you plug in the HDMI cable at the same time, then go to the system settings and change the type of plug you want to use, choose the HDMI, and the screen should flicker then show the signal from the HDMI, then just power off and/or unplug the analog cables, and you are using HDMI. hope this helps, if so thanks for the ratings
Mar 31, 2009 | iLO 3200 32 in. LCD Television
No surround sound, when playing blue ray films using ps3
Im guessing you are using a HDMI cable,
HDMI cables struggle to carry audio...
you will need a componet cable, this is basicly the same quality, and all you do is plug the audio cable part into the surround sound system and done.
Hope this helps
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,725 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
