Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung lcd 32" hd ready
My samsung lcd when turn it on has one white line across the screen permanent no move still the same position everything else fine, what can i do, can it be repair,how much? many thanks doice
  • 102 Answers
It requires repair, 1-2 hours. Or $50-$100
Posted on Oct 06, 2007
SOURCE:
Is there any way to get rid of shadow marks or burn spots
Burn is is usually permanent(must replace panel, NOT cost effective)
You may have a screen position in your menu to try to wipe it, where the screen stays all white or wipes across screen from black to white to try to clear it) If it is burned in bad enough now it is too late.
May 06, 2014 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My samsung 37" screen has black lines running down it, can this be solved simply? thanks
Try diffent inputs to isolate the black line problem to LCD screen? LCD screen can be replaced but very expensive.
Sep 19, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Red thin line on left side of screen / black colours have a burnt red tinge over them. TV is 30 months old
If that line is permanently on the screen  - even when you are using the AV signal then the LCD panel is busted, no way to repair it. Try getting it replaced under warranty, it shouldn't have failed so soon
Oct 30, 2009 | Samsung LA32A450 32 in. HD-Ready LCD TV
I have a Samsung hdtv model LE32R74BDX. I have had it now for just over a year and appox. 6 month later we had 3 black lines to the left of the screen about 3cms apart. The lines are quite thick and start...
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Mar 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
157 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
