Question about Sony Playstation 3 (PS3) Console
PS3 not working through HDMI cable
Hi, I am from the UK and hope you can help me with what I can only describe as a mystery! I have been playing my PS3 thru an HDMI cable on my 50" plasma TV for a few months without any problem. All of a sudden a couple of weeks ago....no picture or sound on HDMI channel. TV says 'no signal'. My sky satellite box can play through the HDMI socket on my TV OK so this kinda rules out the TV and the HDMI socket on the TV. HDMI cable has been tested and is OK. I even tried two other HDMI cables without success. So you would think the problem was with the PS3. Nope... I have another PS3 console which I have hooked up to an LCD TV thru an HDMI cable to my LCD TV in another room. This works fine. BUT, when I connect this other PS3 consoleto the Plasma (via HDMI), this doesn't work either! Both PS3 consoles work perfectly on my the LCD TV. Just so you know, my TV is set to HDMI as it always has been. I am currently playing the PS3 thru the regular audio/video cables but when I try to set the PS3 to HDMI on this channel,nothing happens. I've tried everything short of dropping it from a great height so can you guys help me out??? Look forward to hearin' from you. Many thanks. Badgeman!
  • 15 more comments
  • Riskbreaker Dec 17, 2007
    I have also tried my PS3 with different HDMI cable (I was using DVI output) and HDMI to HDMI it works fine on another TV but when it comes to my TV which was working fine, now it does not display thru DVI (it was doing).
    Only possible failure seems to be with TV but it is functioning well on all other functions.
  • FKFHNJ Dec 20, 2007
    I HAVE THE SAME PROBLEM. DOES ANYONE HAVE AN ANSWER YET ALSO I HAVE THE SAME TV
  • Anonymous Jan 02, 2008
    When putin my hdmi cable in both tv and ps3 i switch the ps3 on but it wont come on the screen just stays black does any 1 no exactly what to do to set it up correctly
  • quin99 Apr 26, 2008
    HI,I HAVE A SONY BRAVIA MODEL KDL-32M3000 AND I TRY TO CONNECT MY PS3 WITH A HDMI CABLE AND IT DOESN´T SHOW THE 108OI OR 1080 P SIGNAL JUST THE 480.SHOULD I LOOK FOR A SPECIAL CABLE?
  • Anonymous Aug 14, 2008
    same exact problem
  • muddy414 Aug 23, 2008
    my ps3 just stopped showing video thru my hdmi cable i had to reset the system just to get it to play thru my rca jacks
  • dcdemon Dec 24, 2008
    I got the same problem too...
    I even recorded it, and made a youtube video.
    The problem still hasnt been solved. I have a Sony Bravia (brand new) KLD-46z4500 LCD which the PS3 has been working with, for the last 14 days. Now its just the sound and black screen, and I have tried everything.. PS3 works fine on other LCDS, TV works fine with xbox360 (through hdmi..) they just wont together.
  • kjones555 Jan 09, 2009
    I have a 50" Toshiba and a PS3 and its not working through either of the TV's hdmi ports.  I tried the first one and the second one...nothing.  I have a blu-ray player hooked up through hdmi and it worked fine on both inputs so I know it's not the hdmi port.  Tried the hdmi cable from the blu-ray player...still nothing.  Even tried the cable hooked up to the PS3 on the blu-ray player and the player worked!  Last, I tried moving my PS3 where I had it before, on a Bravia and it worked fine...why won't the PS3 play on the Toshiba?
  • Anonymous Jan 22, 2009
    Had the exact same problem but thanks to Bubbachuck post above its sorted :) Unplugging the TV for 5 minutes worked. Thanks :)
  • Anonymous Mar 07, 2009
    thankx to all u guys my ps3 was not showing in hdmi like it was before but now that i have listened to yall comments it finally worked to anybody who have any problems with ur ps3 this is the page u need to be on
  • Anonymous Mar 22, 2009
    Trendannoyer is the solution. Do just as he stated and it audio and video will come back. Thanks Trend
  • doedoe4098 Apr 22, 2009
    The other day i'm playin a game and it freezes on me, so I turn off ps3 and go to bed. Few days later I go to play game and I have a black screen and gameplay sounds. Any ideas?? Thanks
  • maxwelldunhi
    maxwelldunhi Oct 27, 2012
    MY BOIL TRIP OUT THE ELETIC WAYLES I WAS ON IT NOW WEN I TRY TO RE CORNET IT NOT WORKING I HAVE TRYED A SCART LEAD AND IT WORKS
  • yassin_benam
    yassin_benam Nov 10, 2012
    me two it wont work no image so do i have to buy annotre hdmI
  • yassin_benam
    DO i buy a new HDMI ?
  • yassin_benam
    becase my HDMI wont work on my tv no image no sound i need help guys do i but a new HDM
  • papabearkod
    papabearkod Jan 31, 2014
    I had this problem. It was working one day and the next not. having not moved or touched nothing I figured it was going to be an internal thing. I did a bunch of things suggested in the forums then read about hard starting the tv. My 50' is only one month old so i thought no way right? Well unpluged waited a few pluged back in and there ya go it was working. Whew!
Connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
  • 6 more comments
  • mrbjt51 Sep 23, 2010
    Amazing! Thank you so much would have never figured that one out in a million years!
  • mehowe Nov 03, 2010
    Worked perfect!!! You would think Sony would put this in their knowledge base. I was about to send the unit in to be serviced. Thanks for saving me a lot of $$$$
  • Cherrylious Nov 15, 2010
    Whoever you are I want to thank u!!!!!! ;)
  • mikoni Dec 26, 2010
    Your a life saver. I recieved my ps3 free because of this problem and now it's fixed. thank you again.
  • carljoseph_g Dec 31, 2010
    does it work on samsung lcd ?
  • peddy78 Jan 30, 2011
    beltin trendannoyer,excellent
  • jeffmasters8 Feb 07, 2011
    my ps3 80g won t play through hdmi cable. I tried a different TV no luck both tv s support 1080p. I hold down the power button and it shuts off. I unhooked both ps3 and tv from the wall for 5 mins and didn t work. When i hook it up with the cord it came with it works and says theres an hdmi device detected but when i select ok to use hdmi no picture through the hdmi channel
  • Wbart001 Nov 14, 2011
    I want to s your d
Power down and unplug TV.
Power down and unplug PS3.
Wait three minutes.
Plug-in and Power up TV
Plug-in and Power up PS3.
When the PS3 restarts, it will sense that you have an HDMI connection and will ask you to verify a few things including screen resolution. Answer the questions on the screen and you should be watching blu-rays in no time.
Generally speaking, what you are trying to do here is just re-boot and start from the beginning. In my case I received my PS3 before my HDTV so I connected the PS3 to my low resolution projection TV using the component connectors. After my LCD/HDMI TV came in I moved the PS3 to the new TV and had no luck with the HDMI connection except for sound.
Posted on Jan 31, 2009
  • 2 more comments
  • junior54321 Aug 27, 2010
    it worked the fist time but i didnt wor the second
  • 2ndR8 Nov 17, 2010
    This was the answer for me too man, I tried every other thing on this page but you win the hero prize!
  • john romeo Oct 23, 2012
    i did everything still doesnt work. i do not understand it use to work fine?
    i did everything and it still does not work?? it use to work fine! i do not understand?
Wow I had the same PROBLEM. It drove me insane because I would take it to my neighbors LCD TV and it would work perfectly there. And then I would come back to my room and then it would sometimes miraculously work again.
After tedious online searching, I FINALLY SOLVED THE PROBLEM.
I can safely say that it's probably NOT the PS3. Go here for solution: http://forums.whirlpool.net.au/forum-replies-archive.cfm/1029039.html
I'll copy and paste the relevant info, courtesy of erucmm at whirlpool forums:
eruccmexcuse me if repeated;
I have the Sammy, and this happens every now and then. BUT i have the fix, it works EVERY time and its simple.
Turn TV off, take power cable out of TV leave for 2 minutes, then plug TV in and start playing.
I find that this occures when I swap from RCA TV to DVI PC to HDMI a few times, its like the TV just gets confussed or something. I found the answer to this on the Samsung help forum site. Many people running PS3's on the 42" and bigger TV's are having the same issues.
Hope this is your problem and not something more serious.
E
So to summarize: UNPLUG YOUR TV AND LEAVE IT FOR A FEW MINUTES. I'm guessing this discharges the capacitors or something "resets". Then do the old "hold down the power button for 5 sec" on the PS3 and VOILA!
Now...how much you guys wanna bet this is due to HDCP? I bet there's something screwy with the algorithm that is preventing people from "hot swapping" video ouputs.
More details: My monitor is the Dell s2409w and I use it as both my computer monitor and my PS3 display. This problem has occured twice and the last time it occured was when I brought my monitor to my friends house and hooked it up to VGA.
Posted on Dec 16, 2008
  • scottrad666 Oct 17, 2010
    Thanks bubbachuck, this really helped. I just turned on the TV, switched its menu to HDMI, THEN whilst my PS3 was off (but plugged in with red light on) held down the on button for 5 seconds, it beeped and I could finally see a display!!! then I could change the resolution. sweet, thanks so much
  • mom2caden Dec 05, 2010
    oh thank you so much. my husband gave me the job of figuring out why ours wouldnt work... Yours was the first sulotion I read and it was fixed in 30 seconds... now i can work on my Christmas Tree... lol
  • 709 Answers
Hi Badgeman, I repair PS3 Consoles and other Video games, It is apparent to me that you have what is ailing many of the PS3 systems, I am finding the HDMI socket is poorly soldered, and not well supported mechanically. I believe your HDMI socket need to be resoldered. Probably on both your PS3 Consoles. This is common. My service in the USA, and I do not believe it is reasonable for me to repair your PS3 since Shipping and all prohibits the service. www.playstationclinic.com
Posted on Oct 07, 2007
Hi Badgeman, I had the same problem with my projector. It was not a problem with the ps3 it was the projector. I turned the projector off at the wall (not with the remote) turned it back on. HDMI worked fine after that.
Posted on Oct 08, 2007
Same problem, tried the other suggested solutions, then used the old reliable. I unplugged all components in the system, actually turned the power strips off in my case, waited a minute, replugged, problem solved. Additionally, this problem recurs for me and I have been able to solve it in different ways, and I like to try various solutions, but when I'm ready to watch a movie, everything gets the power disconnected and this method has yet to fail.
Posted on Oct 24, 2009
I have the same problem as Badgeman, This is second unit I got replacment from sony and same thing on one new LCD HDTV and one DLP HD projector. tryed it on my neibors new hdtv for ha, ha's and it worked??????? Did the first PS3 do something to my HDMI inputs mybe fried them or somthing. I have ued it flawlessly for about 4 months and then nothing on both. I do get sound on optical but no HDMI picture. My surround lacks HDMI connection to test for audio through the HDMI cable. and I bought a $150.00 hdmi cable to rule out that problem. I called sony and they said the DLP HD Porjector wasnt supported by the system??? it is a theater sysem what was 1080p for then??
Posted on Jun 26, 2008
  • McM1982 Jan 26, 2011
    try unplugging the tv completly for a minute and restart the tv and ps3, i had the same problem and it worked for me.
  • acg110981 Aug 21, 2011
    thanks a lot man i tried the 5sec reset with no luck unplugged the tv and ps3 and boom back in business
It just happened to me. I turned the PS3 on and got the black blank screen of death. I tried all of the above and the only thing that worked was to turn my 50" plasma off as well as disconnect the power cord for a couple of minutes and voila, problem adverted.
Posted on Nov 27, 2009
I had the problem of the hdmi lead just giving up all of a sudden so changed to scart lead then realised quality was real bad brought a new hdmi lead and could not get it to work so i exchanged it for a better one and again no luck tried everything .so i decided to take my ps3 apart and found that one of the small pins in the back of hdmi port was pushed right in causing it not too make contact i used a small screw driver to push it back into place .after i put the ps3 together it worked perfectly .just thought i would say that only try this if you feel confident you can because you need to take the whole machine apart to get to the back of the hdmi port i did this because my machine was out of warrenty
Posted on Dec 19, 2009
Fdfa
Posted on Nov 09, 2008
  • jmpasuncion Nov 09, 2008
    i have a problem with my ps3, everytime i turn on my ps3 the key tone wont work and then it does. My screen is also way darker. pls help i use an HDMI on a 80 gb PS3
    Problem Solver:
  • 5 Answers
Hold down your power button for 5 secs and it will reset its self
Posted on Sep 19, 2009
Hey Badgeman
- I dont know if this was posted below, didn't have the time to check as I'm in a hurry, an I'm also sure to forget writing this if I come back later. I had the same problem as you, I tried alot of stuff, some solutions from this thread even, none of them worked, I know this post is old but for people that google this like I did, they should try this too. I turned on my telly, switched to the HDMI-channel my cable was plugged into, turned on my ps3 and pressed to, cd-eject key to get my bluraydisc out, and from that it was all cheesecrackerbuttersliding.
Posted on May 17, 2010
Thx guys... it work for me by reading ur adds... so hold for 5 seconds and it works.. thx again
Hi everyone, if the advice below did not work, do the following:
  1. connect machine using the stock red, yellow, white cable that came from ps3. If you get audio and video then:
  2. backup your system (if you don't want to loose anything in your PS3 harddrive)
  3. Go to systems and then reformat harddrive.
  4. Plug back in HDMI cable and switch TV to HDMI output. It should then work. Hope this helps and only recommend if all else failed as you will need to reload and reupdate everything once done.
Posted on Feb 01, 2011
Kjones555 here's what you need to do.If you check out my youtube video I have already posted the same message over there.
1) Try with two different playstation 3'es on the same TV that doesnt Work.
If they both show "NO SIGNAL", then do the following,
Try both of them on another television.. if the image shows with both PS3's on another TV,
then it is your 50" plasma's HDMI Board that is defect.
I found out it was my SOny bravia (Brand new) which had a defect hDMI PORT, by testing it with 2 ps3's (just to be sure). Both Playstations worked perfect on other LCDS.
So I sent it to Sony and they changed the main board inside it and it works perfect today.
Test the TV with 2 PS'3s with different HDMI Cables,
and then test them on another TV. Its the only way to be 100% sure.
Posted on Jan 10, 2009
I have the same problem.... Me and my brothers ps3 will Not work were thinking becuase My brother keept reseting the ps3 Again and again, becuase he was putting it on diffent tvs ALOT and then, he put the ps3 on a tv that only worked for ps2 hookups so he dident use hdmi he used AV multi outlet/hole thingey and now the ps3 dosent work on hdmi Plz help me I need my better graphics back PLLLLZZZ so thank you!
Scincerley, Sarah
Posted on Oct 04, 2011
I don't know if someone else post this solution sorry I didn't read everithing but I have the same problem, my HDMI works fine, but some day it didn't, I have a Bravia KDL-46V5100 too brand new and my PS3 Didn´t work with any thing, and belive me I tried everything, --restore -format -push 5 seconds. -turn on PS3 and then hold off until my PS3 get off again and then turn it on but holding again until I hear 2 beeps then connect the control and put all the option it appear (obvious my RCA cable was connected and all doing it by RCA)and nothing. -etc.
The only thing that works for me was
to turn off my PS3 and my tv, unplug both wait for 15min, then plug to wall my PS3, switch the main power from the back of the PS3, when the red light is on, power on the PS3
-Then plug to the wall my TV and turn it on and voilá!! it works, something in the bravia (I think that in other Brand works the same way) resets something and it recognize the HDMI from default.
Really I was desesperated coz I was playing in HDMI and sudenlly it stops displayng in HDM (sorry if my english is confuse but I'm from México living in México )
Posted on Jul 13, 2010
  • 3 Answers
Hi folks I had the same exact problem exept me it happened while playing... the picture started to pixelize and to blink :S after 2 hours of playing... I've tried all the previous solutions and still didin't work. My PS3 was still garanteed and I finally shipped it to Sony.. and they finded out that the HDMI output socket was malfunctionning... maybe due to ''overheating'' or it even desoldered/dewelded from the PS3 mainboard.. whatever now it works fine... probably a weak assembly by Sony... go figure lol
All I have to say it that if you've tried EVERYthing from the previous posts to make it work and it still dosen't and that your warranty is over, take your PS3 to any Audio/Video repair shop, they'll change the HDMI output socket and/or weld it to the mainboard and VOILà! costs around 60$ to 150$ depending on if he has to replace the socket.
Posted on Mar 14, 2010
Yh one bout holding the power button did not work but thanks anyway
Posted on Nov 06, 2008
Hi Badgeman,
  • lee small Sep 28, 2011
    hi my name is lee small my ps3 does not work with hdmi cable i have got new cables for all you bits you need for ps3 but whan i turn it on i get power but no pic or sound i have look at the hard dive it seems ok can you pls help me
    Problem Solver:
  • 10 Answers
Make sure you don't leave it on after playing. And that you don't take the HDMI cable out. If you leave the PS3 console on for too long then the T.V won't give good connection or signal.
If it's something else like game not working then makesure to put it back into it's case remember don't just leave it there lying in the sun or the sun can do something to the data to make it not work at all. Remember don't leave the game in the console for decades!!!
Posted on Dec 27, 2010
.01 is all we paid for the HDMI cable and when we hooked it up - it didn't work....scared. Samsung 26" lcd and Sony PS3. We did everything listed above but here's what worked:
1. With both tv and ps3 running (Not properly at this point but plugged in and turned on)
2. He Changed the "settings" on the TV to HDMI (instead of AV).
then
3. he Changed the PS3 Display Settings to HDMI
then
4. the playstation system processed the changes where we responded to the questions that were generated automatically on screen by the PS3 checking.
My 16 year old son figured all that out on his own with me sweating my 1 penny HDMI purchase (sorry for the long story but it all worked out in the end it working great - he's online playing).
Posted on Jun 16, 2010
3 Suggested Answers
SOURCE: PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Posted on Oct 20, 2007
i am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
Ps3 turns on but no signal on tv
Hi There,
Is the TV set for the correct input?
I assume you are using HDMI?
If all settings and input selections are correct then I will have to say that either the HDMI cable is faulty, or the HDMI port on either the TV or PS3 could be faulty.
Check if PS3 can work on another TV with the HDMI cable.
Check if another Device can work on that TV with the HDMI cable.
Try another HDMI cable.
From this, you should be able to determine where the issue is sitting.
Hope this helps!
Jan 13, 2016 | Sony Playstation 3 (PS3) Console
Hi. Please help. I'm using sony Bravia klv-s3210,
Change the resolution for the picture to match the resolution from the PS3. It probably will never work as VGA does not support HDMI resolution.
Jul 25, 2017 | Televison & Video
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
No surround sound, when playing blue ray films using ps3
Im guessing you are using a HDMI cable,
HDMI cables struggle to carry audio...
you will need a componet cable, this is basicly the same quality, and all you do is plug the audio cable part into the surround sound system and done.
Hope this helps
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Some games wont play on my ps3
Hmmm...are you using the latest firmware?
You could always call Sony for a direct answer @ 1-800-345-SONY
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
88,060 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
john o grady
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
