Question about Car Audio & Video
My car stereo
I brought a new kenwood Kenwood KDC-237SA CD Player for my nissan almera last week. I was able to remove the old stereo no problem. Connected up the my new stereo and when I went to turn it on the lights on the stereo flashed then went off. I automatically assumed that the new stereo was at fault so jumped the gun slightly and got on the phone to the supplier and had a right go. Long story short, removed the new stereo and fitted the original stereo only to find that the old stereo also stopped working. I assume that something with the internal wiring has gone wrong somewhere. where do I begin checking to try and find a fault?
CHECK YOUR MANUAL. SOME KENWOOD (AND OTHERS)  USE A DIFFERENT WIRING CONFIGURATION WHERE ONE OR TWO WIRES HAVE TO BE SWAPPED AROUND FOR CERTAIN CARS. ITS NORMALLY THE RED AND YELLOW WIRES THAT NEED SWAPPING.
OTHERWISE, CHECK THE LITTLE FUSE AT THE BACK OF THE UNIT. THE POWER MIGHT HAVE SPIKED WHEN YOU CHECKED YOUR UNIT AND BLOWN THIS.
GOOD LUCK
BUNGIE
Posted on Oct 31, 2007
  • 102 Answers
Check the fuses
Posted on Oct 06, 2007
SOURCE:
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Cost
I'd give you $80 for it used , New msrp $150usd
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 25, 2009 | Kenwood KDC-3027A CD Player
I have no sound
just because the wire loom looks the same doesnt mean it is check the manufacture's website for any information you can find.
Feb 14, 2009 | Kenwood KDC-V6017 CD Player
Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Feb 03, 2009 | Kenwood KDC-MP228 CD Player
Kenwood car stereo radio works but cd player want says code off any suggestions
tengo un carro con un stereo kenwood kdc -mpv7019 como lo puedo desbloquear
Jan 09, 2009 | Kenwood KDC-MP5028 CD Player
Cd player comes up with ''PROTECT''
one of your speaker wires to the internal amp is shorted. turn power off and make sure they are not touching metal or each other and then hit reset again. if this doesn't help your power ic may be fried inside the stereo or a speaker is shorted.
Nov 14, 2008 | Kenwood KDC-MP435U CD Player
GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Sep 18, 2008 | Kenwood KDC-W3037A CD-receiver,...
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Car Audio & Video Logo
387 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
