Question about HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop
Background i asked this question once and it didn't help so i'll ask differently i can't change my background or wallpaper other than custom color i tried the set as background button and it did'nt work either its as if it is frozen or something i can't scroll or anything iv'e tried the control panel,display nothing I do seems to make a difference help please
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
Before reading below please make sure you are familiar with registry modifications. It is very important to know what you are doing. THE FOLLOWING INFORMATION MIGHT HARM YOUR WINDOWS SYSTEM AND MAY MAKE IT STOP WORKING. USE IT AT YOUR OWN RISK. A virus, certain spyware, a malformed registry, or other circumstances can transpire making it impossible for you to change the Windows XP desktop wallpaper. When you try to modify the background picture, neither the list of images nor the "Browse" button is clickable. If this happens, you can perform a registry tweak to restore the functionality. Note you must be an Administrator to perform this tip. NOTE: Be careful what you are doing when modifying the registry as you can harm your computer or keep it from booting! Read the disclaimer. 1. Run "Regedit". START / RUN / and type Regedit and click OK 2. Navigate to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows\CurrentVersion\policies 3. If you see a folder (key) "ActiveDesktop" select it. If not, make a new key and label it "ActiveDesktop". 4. If you see "NoChangingWallPaper", double-click the DWORD value and set it to "0". Otherwise, you need to create a new DWORD value of "NoChangingWallPaper" and set it to "0". 5. Try changing your wallpaper. If this fix doesn't solve the problem, you may also need to make the above registry changes at location: HKEY_CURRENT_USER\Software\Microsoft\ Windows\CurrentVersion\Policies .
Posted on Oct 06, 2007
SOURCE:
My le pan II background color changed to a mixed red - is the display going out?
Sounds like an app changed your wallpaper settings. Try this: go to settings then click display, you will see what wallpaper you have on th list right. Touch wallpaper and choose whatever you want then click set. This may bring everything into focus with the background you need for the correct page. It seems sometimes the LePan changes color but it is actually the wallpaper somehow taking over. Let me know if changing wallpapers works to "right" the situation. I hope this helps
Apr 09, 2014 | Le Pan II 9.7" Tablet PC
LG VX6000 'I Love You' wallpaper
ok.. is animated wallpaper.. i.ll find one like that for you..
just wait for a while
May 05, 2008 | LG VX6000
Tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 | Computers & Internet
MY LAPTOP DOES NOT ALLOW ME TO CHANGE MY WALLPAPER
right click the desktop and go to properties. click change background. If your background is custom made i think you need a jpg or gif picture. once chosen hit apply thehn ok
Sep 07, 2013 | Computers & Internet
My Acer Aspire One netbook only changes the wallpaper to solid colors.
one day my desktop switched from my selected theme to solid black. I could not choose anything else until I activated Windows - because the "trial period" had expired.
That was also in Win7
May 03, 2017 | Acer Aspire One D257-13473 Netbook
Wall paper for windows 7 starter
Hello there,
Its one annoying limitation of Win7 Starter edition.
Download
Once you install Starter Background Changer on your Windows 7 Starter system, you'll find a new Personalize command added to the desktop context menu - the one that pops up when you right click on the screen. Select it, and you'll be able to customize your wallpaper straight away
1. Download the file on the link.
2. If the download doesn't start automatically, check again.
3. Install the file.
4. Look for the Personalize command added.
5. Change your background.
Hopefully this helps.
Thank you for posting..
Jul 14, 2011 | Computers & Internet
I cant change my desktop background ..
To change the desktop background:
1. Go to Start>Control Panel>Appearance and Personalization>Change desktop background.
2. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
3. Select the box next to the picture that you want to choose as your wallpaper(this will put a check in it.)
4. If you want the picture to fill the screen, under picture position, select "Fill."
5. Click "Save Changes." in the lower right of the window.
Another way to change the wallpaper-
1. Right click an empty spot on your desktop.
2. Click on Personalize. (This will bring up the personalization window with themes in the main window.
3. Click on the blue link "Desktop Background"
3. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
4. Then follow steps 3-5 above.
Hope this is helpful-Thanks for using FixYa.
Apr 30, 2011 | Samsung X15 Notebook
How to change my wallpaper in my laptop
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don't forget to vote
Feb 12, 2011 | Computers & Internet
How do i take off my background pic?
The user manual is available here; http://www.playstation.com/manual/pdf/PSP-1001K-2.7_1.pdf goto page 102 (Theme Settings) and change the "Wallpaper" to off. Hope this helps :) p.s. the manual is for software version 2.70 which is the one previous to the latest. If your version has different theme menu, please ask again.
Sep 03, 2007 | Sony PlayStation Portable (PSP) Console
HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
