Question about Hoover S2571 Quick Broom Bagless Stick Cyclonic Vacuum
Problems with Vac.
The vacumm turns on but does not pick up anything. Does this model use a belt or not? I already have another vacumn so if it is going to cost too much to fix, I will just continue using the other one. Please let me know what the problem can be and I will try to fix it myself first and then if not I will just get rid of it because it is just taking up unnecessary space if it is not going to be used. Thanks.
  • ojchilibug Dec 30, 2008
    I have the same problem but I have cleaned my filter. It sounds like it's working fine but it's not picking up anything.
  • 102 Answers
Check that the filter is not clogged. It needs removing and washing every 6 months.
Posted on Oct 06, 2007
The brush has stopped rotating so vacume won't pick up anything.
Without knowing the brand and model number, I can't assist too much. However, most all of them have a belt that turns the rotating brushes or "beater bar".
It looks like a large black rubber band, and does wear out at times causing this condition. It would be located under a removable panel on the bottom of the unit.
Jan 06, 2017 | Vacuums
How do I fix my vac?
Is the belt on the beater bar broken? You can check it by removing the screws that are on the bottom and taking off the plate. Look at the long bar that run across the bottom and there will usually be a belt that turns it. If that is broken it causes problems. If not the belt then maybe the filter. If you cleaned everything and you are sure there is no blockage you might just have to go out and purchase a new vacuum. You did not mention what model of vacuum it is.
Feb 21, 2015 | Vacuums
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
My dirt devil ultra vision won't pick up anything and the brush does not turn, also smells like rubber is burning. What should I do? I checked to see if it was clogged and the belt is not broken.
Sounds to me like the belt has gone or at least stretched so it is slipping on the spindle, take the brush out and check for hair or anything wound round where the belt grips...don't know this particular vac but usually belts are not too difficult to change. Get a new belt from your hardware shop
Jul 11, 2011 | Vacuums
MY Vacumn seems as though it is not picking anything up. It is also making more noise than usual. I cleaned both the filters and looked to see if something was clogged. Maybe I am missing something. ...
Well check the entire system for dust blocking the air. If it's not in guarantee anymore try checking the main fan, it could be missing some parts. Also, check how much air is going out the vacuum
Feb 28, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Not picking anything up off the carpet
You need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Feb 16, 2010 | Vacuums
My vacumn wont pick anything up and it wont self propel. I checked the belt - it is fine.
There are numerous things to check.
  1. Check for hose clog
  2. Brush belt has many hairs and doesn't move
  3. Brush belt broken/loose
  4. Vaccum bag is full
  5. Height adjustment according to floor.
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Not sucing
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Nov 08, 2009 | Eureka Capture Upright Vacuum Vacuum
Hoover S2571 Quick Broom Bagless Stick Cyclonic Vacuum Logo
118 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
