Question about Philips WMM142211 Turntable
Started playing too fast, now won't turn
I have a philips 437 synchro belt-drive turntable. it suddenly started playing too fast. i unplugged it, plugged it back in, and now it won't turn at all.
  • Anonymous Sep 06, 2008
    Hi.
    I have a Philips FCD560. For sometime now the turntable has been tempremental. As the arm comes over the record it should start the turntable, but now it does not do that at all.
    The belt is fine as far as I can see.
    What next to look at?
  • Anonymous Mar 26, 2014
    I have a ste of soundlab direct drive turntables but one plays up when i press the start button, if i turn it slightly it will start, being a DJ i need to get it fixed, ?
  • 102 Answers
Check that the belt has not perished.
Posted on Oct 06, 2007
My PTCDS1U just started playing too slowly despite my attempts to adjust the speed
Is this a belt drive turntable? If so, replace the belt - its slipping.
Dec 30, 2013 | Pyle Pro - PTCDS1U - Home Ptcds1u...
Philips 437 turntable
You could try the Philips website. They might have a free PDF of it!
Sep 09, 2013 | Philips Audio Players & Recorders
My teac pa688 plays only on 45 now the turntable wont start just hums thru amp
If it's a belt drive the belt could have become slack or something and slipped off it's correct position.
Mar 30, 2013 | Audio Players & Recorders
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!
are you sure, that your speed selector is on 33.3rpm, not 45?
assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.
Good luck,
Alex.
Jan 11, 2012 | Aiwa PX-E860 Turntable
My Sony PS-LX250H Turntable suddenly started playing records too fast for both 33 and 45 speeds. Any ideas on how to fix???
If this is a belt drive then most of these speed increases are caused by the belt being in the wrong position. The belt could be faulty and my need to be replaced. Otherwise it could be due to a power supply problem, such as a faulty regulator to the supply of the motor. A check on the voltage to the motor will determine this. Assuming you know what the correct voltage should be! Of course with luck it will be higher than the motor is supposed to run at.
Feb 02, 2011 | Sony PS-LX250H Turntable
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Open Questions:
Philips WMM142211 Turntable Logo
592 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
