Question about Yamaha Audio Players & Recorders
Shutting off I've had my Yamaha reciever for 9 months and never had any problems with it until shortly ago. All of the sudden now it runs for 4 or 5 minutes with sound, then just shuts itself off. I checked my wires to make sure they weren't crossed, and they were fine. Then I tried unplugging all speaker wires and turning it on, again 4 or 5 minutes and it shut off. I tried reseting but that didn't work either. It's well ventilated area so that isn't the problem either. Any help would be appreciated.
  • Anonymous Jan 25, 2008
    I have the same problem...sometime it will be fine four a few hours, some other time it will shut off after 1 to 5 min.
Same here... except now it won't turn back on :(
Posted on May 30, 2008
SOURCE:
I am getting Misfire Codes P0300, P0304, P0306 and a P0420
don't know how many miles are on the car ,but I would change the spark plugs
Nov 26, 2013 | 1998 Dodge Ram 3500 2WD
My husbands MSI A5000 laptop suddenly stopped being able to get on the internet. It says he is connected but he can not accessing the internet. It was working fine until he hurriedly put it in its case to...
Solution based in assumption that the laptop is connected to the internet
> Go to run type cmd
> In the dos window type "ping www.google.com"
> look for packets sent and recieved
> If packets recieved is 4 then try a different browser
> If packets recieved is 0 then you are not connected to the internet
Oct 11, 2013 | MSI Computers & Internet
Athlon 64 X2 5200+, 2.6 GHz desktop only runs on power saver setting
Hello there!
Perhaps it is time to change or recalibrate your battery, some of these particular issues, came from a old or faulty battery. other that that, its a motherboard capacitor blown issue, it can hold electricity, but the capacity to do it came to and end.
Carl
Mar 18, 2017 | AMD Athlon 64 X2 5200+, 2.6 GHz
1997 buick hard to start why?
Have the fuel; pump checked for pressure bleed down after sitting, it should hold pressure within 5 PSI of rated running pressure after shutting sown the engine for extended periods.
Sep 02, 2012 | 2002 Hyundai Santa Fe
How to have more mileage without compromising the power and speed???
Some of the general points are given below if followed will help you a lot on daily basis 1 Cut down on Static running of the engine. Reduce the idling time 2 Do not accelerate with out any reason when you start in the morning. 3 Fill the right fuel and oil. 4 Always run the vehicle on the recommend speed by the manufacturer which is given in the manual provided. 5 Avoid sudden burst of speed and then slowing down by sudden breaking. 6. Keep the tire pressure correct as less pressure burn more fuel and use more power. 7 Clean the spark plugs every fortnight. But once a month is a must. 8 Do not Overload. 9 Real good tip which you may not have been told i.e. When you reach the particular speed and are running it on for some time, reduce the acceleration. This way the vehicle will run without extra consumption of fuel due to the momentum it has already gained. This can cut down consumption fuel by 10 - 25 % depending on the nature of drive, short or long.
Dec 09, 2010 | 2008 Yamaha YZF-R15
Battery loses charge
you may have shorted some wiring when you installed the new stereo
Aug 31, 2009 | 2002 Mercedes-Benz C-Class
Problem with Lightning McQueen Tv/dvd combo
hi sir..
u told 9 monthly only. see whether it is in warrenty period.
Sep 02, 2008 | Disney DTD1363-CAR 13" TV/DVD
Yamaha reciever
part of it more than likely is your power supply or outlet.
two the draw on your other componets could be shorting it.
Nov 15, 2007 | Yamaha HTR-5730 Receiver
275 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
