Question about Optoma EP738 Multimedia Projector
Ep738 not creating any image just a white grid.
As I turn on the projector and the white Optoma logo normally pops up on a black background. Instead what happens is it goes to a white grid and no matter what I do it just shows the white grid. I tried cleaning out all the dust but that didn?t help at all.
    New Friend:
HI i had the same problem with my Optoma showing the white grid when turned on, and it is not a problem of the lamp not being good good. Sounds odd, but i removed the lamp. then dropped the projector against a hard surface from say 10 inches from floor, tehen a hard tap on the side, then inserted the lamp back in, turned on the darn thing, and it showed the Optoma logo alright, with 2 vertical stripes, then i removed the lamp again, repeated procedure, and by this time the lines wer gone and i got the projector to work again, including all push buttons on panel (this wasn´t possible when i had that problem. It really worked for me. At least you can try it.
Posted on Aug 01, 2010
  • 3 Answers
Have you tried a new lamp?
Posted on Apr 20, 2008
SOURCE:
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
Hi, I have a projector Optoma EP7155 and it appear white and black spot like dead pixel, I would like to know where I can buy a DMD chip with the CCD and how much it will cost. Thank you
global projectors is one source. You need to find out from Optoma the chip you need or take apart the machine and look at it. From China they run about 200 bucks. I've only done Mitsubishi so far.
Dec 16, 2012 | Optoma EP7155 DLP Projector
The background projects as yellow instead of white. Everything has a yellow tinge to it.
It sounds like one of the polarisers has failed, on experience they cost £300 each to replace, and there are 3 of them. I recently bought an NEC NP115 for just over £200, very good spec for the cost. It maybe worth investing in a new one.
Hope I was helpful for you.
Aug 08, 2011 | Optoma EP771 DLP Projector
I need to reset my projector. It is bazook after I disconnected it incorrectly from my MacBook. It now shows the grid and then it twinkles maddly and the gris reappears, and the whole sequence is...
hy , i have an optoma pk 102 projektor and i have a promblem i start the projektor , shows me the "optoma logo" and than it's starts flashing and restarting , and show again the optoma logo. i try to connect to the laptop and show me the extend monitor for 10 secounds and restarting again, how can i fix the problem,maybe i cand upgrade the firmware?.Thanks
Apr 26, 2011 | Optoma PK102 Projector
My optoma is projecting white spots onto the screen. They seem to just appear. Some have began by 'sparkling' for a while and then they stay white perminantly.
if it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
May 10, 2010 | Office Equipment & Supplies
Lamp goes out after a few minutes
my 3m projector switches off in 15 seconds indicating the lamp indicator, as the lamp has not been used enough
Mar 25, 2010 | Optoma HD80 Projector
Optoma projector HD806
its not the color wheel. Its the sensor that counts the black tape on the color wheel. The sensor has dust on it. It can't count how many times the wheel is going around because the dust is blocking it. the sensor is located by the wheel. if you have any questions you can callme 610-842-7442 ask for dan.
Dec 01, 2009 | Optoma hd806 DLP Projector
Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
May 12, 2009 | CTX Optoma EzPro 610 Multimedia Projector
Color problems
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Sep 14, 2008 | Optoma HD72 Multimedia Projector
Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Oct 08, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP738 Multimedia Projector Logo
310 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
