Question about Nikon D50 Digital Camera
Flashing "f--" I recently took my d50 up a mountain hike and at the top I took a landscape shot that showed up on the viewer as just a full white/blank picture, and now I can't take any more pictures or focus or anything. I just get a flashing "f--" in the aperture space. Did I break something? How do I fix it? Thanks
Reading your post again, I think what I copied and pasted above makes a lot of sense...it seems like your photo was horribly overexposed (all white) because of lens failure or miscommunication with the camera, which makes sense considering the F--- error.
Hope you get it sorted out...repair may be necessary.
Posted on Oct 14, 2007
"F-- means the CPU in your AF camera body cannot communicate with the CPU inside your lens. That means either your lens is an older manual-focus one and has no CPU or there is some electronic communication problems.
If you have an AF lens on your camera and still get F--, I would first clean the electronic contacts in the lens mount area, on both the body and the lens."
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00JCKn
Hope this helps!
Nikon d-90, shadows in pictures
if you're using pop up flash, you'll get more shadows doing a portrait shot than a landscape shot just due to the position of the flash bulb and the angle the shadows are cast.
Jul 06, 2014 | Canon Rebel XT / EOS 350D Digital Camera
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
D50 wont power up
I have the same problem as well. It is not the battery. I took my camera to the store and had them put a new battery in while there. It never turned on. I really like this camera. I once took about 100 continuous shots. It was great. But now nothing. The D60 camera I have is a higher mega pixel, but does not do alot of things that the D50 does. I wish someone really had the answer as to how to fix it without a high cost.
Oct 06, 2007 | Nikon D50 Digital Camera
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Nikon d 50 black sky
hi first of all dont point towards the sun in auto it backens the screen automaticly set the light sensetuvity lower(more light) good luck
Nov 13, 2005 | Nikon D50 Digital Camera with 18-55mm Lens
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Problem taking panoramas with Pentax S4i
Forget the LCD. The optical viewfinder shows only 72-77% of the actual picture. Just align the edges of the viewfinder and you will have plenty of overlap for stitching. I find it much easier to get accurate panorama shots with the optical finder anyway. You can lock the angle and just rotate your shoulders – much easier than holding the camera in front of you. Are you sure the S4i locks the exposure in panorama mode? My S4 doesn’t, which is one of my beefs with the camera.
Sep 08, 2005 | Pentax Optio S4i Digital Camera
Battery life
Are you keeping the large LCD screen on all the time? If so, that will dramatically reduce battery life. Same goes for flash use (although for 8 shots shouldn't be a factor) and constant stabilization. Also, by low battery do you mean that the camera is turning itself off and can't be turned back on? If just the icon is showing low battery life, it could be that the sensor wrong. I have an MP3 player that will say it has zero battery power, but will really play for another two hours. You should be able to take many more than 8 shots with one battery. I've taken 500 photos over a period of nine days on one battery with my FZ10. Viewfinder only, stabilization only when shooting, no flash use.
Sep 06, 2005 | Panasonic Lumix DMC-FZ15 Digital Camera
Finepix 2400 Dark landscape shots
I was just out yesterday taking pictures in very hazy conditions, and some of my shots were facing south at about noon. I was actually expecting the sky to be overexposed, so I took two pictures of everything, one on auto, and one on manual with the exposure set to -0.6. Well, it turned out that even the ones on Auto were dark, so the ones on the manual settings were even worse! As it turns out, I had the same problem you had, and should have boosted the exposure. Reading the manual, it does say that you should use positive compensation for very bright scenes or pictures of mostly sky. Try it next time and see how that works. I'm new to this too, but I'll get the hang of it sooner or later... ;)
Sep 04, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Nikon D50 Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
