Question about Panasonic CQ-C7301U CD Player
Display does not work
I have this unit in my golf cart. It was working fine and I was listening to a CD when the display went out. the unit will still play. Have you heard of this with this unit and can it be fixed
  • 1 more comment
  • Anonymous Nov 08, 2007
  • Zootys17 Feb 06, 2008
    When you press in on the center it keeps it on, but letting go causes it go go back out. Im guessing it's a connection problem. Odd that the music plays flawlessly though huh?
  • Zootys17 May 11, 2010
    I have the EXACT same problem, only mines worse being itll do this when it hits bumps too, still plays music though.. i press mine in on th center to keep it on but once you release pressure it goes back out, no ones helped me with it yet either tho so i dunno...
  • 3 Answers
It must be a manufacturers defect because i have the same unit in my 2001 jeep grand cherokee and it does the exact same thing. I rewired it and it worked fine for awhile then started doing it again. also try cleaning the input post at the back of the face.
wellgood04@yahoo.com
Posted on May 14, 2008
How can I Speed up my 2004 Yamaha 36 v golf cart short of changing motor
If you are getting full voltage to the motor and that is the best you can do, then you have no recourse other than to change the motor.
Mar 31, 2017 | V Golf Golf
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
Have a cadi cts 03 and my radio display when out cd still works and I check all fuses and there fine what could it be?
If the cd still works then it is just a bad display in the unit , replacing the unit would be cheaper than repairing it.
Nov 02, 2014 | Cadillac CTS Cars & Trucks
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
2006 Honda Accord Vp Stereo System went out and i have checked every fuse and nothing is working! It started out with the DISPLAY ILLUMINATOR now the whole STEREO went completely Is there any
time to rip it out and fit a after market one ,it sounds like microprocessor has packed up and its cheaper to replace than mess around trying to get it repaired
Apr 27, 2012 | Cars & Trucks
2004 honda accord CD player not working
I have the same problem I bought one with the same problem. Does any one have a solution.
Help
Dec 02, 2008 | 2004 Honda Accord
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
Not turning on.
before disposeing the little sh.. look if there is good connection between the panel and the unit try pulling out a little bit the legs of the connection good luck windman
Oct 24, 2005 | Kenwood eXcelon KDC-X559 CD Player
Panasonic CQ-C7301U CD Player Logo
82 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
