Question about Mitsubishi VS-50607 50" Rear Projection Television
Will not turn on
The green power light only stays on for maybe 1second and shuts off.
  • lrdevore Oct 07, 2007
    The self-diagnosis feature is sending error "2 - 4 = Vertical protect (usually loss of vertical from the source.", what is the fix?
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
  • Lashawn Robinson Oct 07, 2007
    Ok this is the million dollar answer! First check solder connection at connector "DY" on the Yokes. 2nd check C411 which is a 2200uf@35v cap and the C412 10uf@50v on main PCB. Change anyway. This should fix your set, but if not you need live chat!
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv shut down while watching a dvd will not turn on screen is black
maybe the problem is in the cathode light located on the top of your screen. Is there a signal light on your T.V? a green light or maybe a red? if there is a green light then we can say that the problem is the the cathode light or maybe the power supply of the cathode light is defective in that case we can use a power supply of a cathode light that usually used in motorcycle as a signal light.If the signal light is red maybe the problem is in the power supply or maybe the main board of your T.V. Hope this may help you.
Aug 19, 2011 | Dynex DX-LCD37 TV
My Zebra 2844 light won't stay green
The amber light means the cover is not closed all the way. Something is preventing the cover from staying latched closed - it's releasing just enough to activate the cover-open sensor. Maybe check if you can see anything broken where the cover latches shut.
Not sure if this will be too helpful...
Apr 14, 2010 | Zebra LP 2844 Thermal Printer
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
Screen turns green then shuts off
Sounds like the green picture tube is arking or shorting out and at that very second the safety circuit senses the problem and makes the complete set turn off,the only way to repair is the replacement of the green picture tube and it can be too expensive.Maybe if you move the complete set from one side of the room to another you might get lucky.Maybe!!!!!!!!!!! is worth to try.
Sep 20, 2006 | Sony KP-61S35 61 in. Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
