Question about Garmin GPSMAP 76 GPS Receiver
GPS screen went blank
While moose hunting I had my GPS on for about 45 minutes and the screen went blank. I tried to turn it back on and nothing happened, I replaced the batteries with new Rayovac batteries and it turned on and went blank again in less than one minute. I replaced the batteries again with new Energiser batteries and it worked fine again with no more problems for the rest of the week long hunt. After returning home from the hunt I turned the GPS on in my yard and the "distance to the nearest waypoint" reading (home) kept jumping from 27 metres to 289 metres, the sceen shifted side to side a couple of times also. Are these problems related? Was the first problem battery related ? Was the problem at home satalite related? Thanks for the help, Hotch.
  • 1 more comment
  • Anonymous Jul 03, 2008
    goes blank with a single line through the screen. Have changed batteries twice .
  • Anonymous Sep 28, 2008
    I have a similar problem...as soon as my GPS starts getting sattelite reception the screen goes blank and has one line through it. If I hit the menu key before sat reception is acquired I can go into any of the gps functions but if I go back to the sat reception page the screen goes blank with a line through it and the only way to get rid of the line is to remove the batteries.
  • timweidner Sep 30, 2008
    I have experienced exactly the same problem described above. I get a single vertical line down an otherwise blank screen after the GPS successfully acquires satellites. I did indentify a contributing factor. My GPSMAP 76 is mounted in my boat with a factory mount and 12-volt wiring harness. I first hooked it up three months ago and have been using it all summer with no problems. Then the problem above occurred. I found that when I disconnected the power supply, pulled the AA batteries to clear the problem, then powered back up on the AA batteries, the problem did not return. The moment I tried the external power cable, the problem reoccurred. Could this be a power overload defense? I have not changed anything with the boat's electrical system. I saw the problem reappear once with the engine running and once with the engine off.
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Posted on Oct 06, 2008
It looks like a software upgrade did the trick in my case. I upgraded from OS 3.8 to 4.0 and the last time I had my boat out the GPSMAP 76 worked just fine.
Posted on Oct 07, 2008
    Novelist:
  • 113 Answers
Its normal for position to shift but not that much.  Try again and look at the sat status screen to see how many satelites you pick up and how strong signal is.
It's most likely that software failure caused GPS to chew up the batteries.  The GPS uses a lot energy while acquiring.
If your software is less than v4.00 then download this update:
GPSMAP 76 Ver. 4.00 as of Nov 29, 2006
If that doesn't work it may be necessary to do a master reset.
Posted on Oct 26, 2007
SOURCE:
MDX 2004 GPS went blank
Probably need to enter the navi code to unlock the gps.
Sep 07, 2014 | Acura 2004 MDX Touring with Navigation S
Display went blank to the calibration screen while traveling
Try using a stylus if you have one or a pen (tip retracted) on the screen. Meaning something finer and thinner then your finger. Don't know why but this works on my unit when the recaibration screen comes up.
Nov 27, 2013 | Garmin nuvi 255W GPS Receiver
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
Oct 16, 2010 | Garmin nuvi 1200 Car GPS Receiver
Turned on my 720 and it did not register any
OOooppps, try connecting to your computer, and start tomtom home software, let it check for updates and see what happens/ comes up on screen, then we will take it from there, OK, Colin.
Jan 04, 2010 | Tomtom GO 700 GPS Receiver
Turn it on screen went blank will not come back on
Hello there:
First if this unit has a restet button it hold it in for 3 minutes and than try it if still nothing, the device has a fuse that is located on the inside of the unit that probablly has failed and needs to be replaced also you may want to make sure that the battery terminals are not loose and are clean.
You can also take it to a authorised dealer to have it bench tested ok?
best regards michael
Oct 22, 2009 | Magellan GPS
Tv wont blank screen
Try to unplug the power for a few minutes and plug it back in. If it still not work then the main board has gone bad. Replace the board will fix it.
Apr 22, 2009 | Vizio L37 Television
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
While traveling in New Hampshire, the screen went blank (green)
It came back on when we crossed the border back into the USA from Canada.
Dec 21, 2008 | GPS
Blank screen. Not working at all.
Try to turn it on while it is plugged into the charger and see if it works. if not, you might need to update your software using this website: www8.garmin.com/support/collection.jsp?product=010-00401-20
Oct 22, 2008 | Garmin StreetPilot c340 GPS Receiver
Fujitsu remote control unit /MODEL AR-RY16
my remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Jun 07, 2008 | Fujitsu 24C1 Air Conditioner
Garmin GPSMAP 76 GPS Receiver Logo
604 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
