Question about Frigidaire PLEF398AC Electric Kitchen Range
Doubel element right front element is a two in one. Large or small. When turned on, only large heats, despite direction of the temp control. I switched temp control with left side bridge element control (same part) - same results. I've checked the wiring schematic carefully and it seems ot be correct (this unit has had several repairs in the past). Is this a control board or element problem. Thanks
  • 473 Answers
If only the outer ring of the element is getting hot then the element is bad. The elements should have a 5 yr warranty that covers the part only so check your owners manual.
Posted on Oct 06, 2007
Why won't my large element on my Kenmore 790.96214404 turn on?
It would take some testing with a volt-ohm meter to know for sure, but it sounds like your element has burned out. It could be inside the little box attached to the element, so you can't see it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 25, 2014 | Kenmore Kitchen Ranges
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Mod # MER5710AAW The small element will not heat on its own power, but when the large front element is used, the small element heats up
chances are the infinite switch failed i would replace the switch for the small burner Part #: 7403P238-60 this should fix your problem.before ordering the part just make sure all the connections ar good on the switches after removing the back panel. hope this helps
Jun 07, 2011 | Maytag Kitchen Ranges
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
Frigidaire PLEF398AC Electric Kitchen Range Logo
122 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Sal De
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
