Question about Kodak i40 Path-Through Scanner
Problem for kodak scanner
I am find the problem error no 7 in the kodak i40 scanner . i am not solved this problem please help me
  • 31 Answers
Face down lamp error, check lamp/ballast connections.
If its still a problem replace the lamp.
Posted on Jul 07, 2009
Kodak i40 scanner error 8 message but lamps are fine, worked OK last week, any suggestions
Check you have the latest firmware , the old version can cause this on startup especially when cold
Oct 10, 2011 | Kodak i40 Path-Through Scanner
Error Code 7 blinks for awhile then locks on error 7
HERE is the service guide for your printer. the error code you mentioned says to call Kodak support and gives no other info.
Jan 07, 2011 | Kodak i40 Path-Through Scanner
Kodak i40 error e7
E6 means the scanner cover is open .
Please check for any open covers or any movable parts which is not closed.
Feb 26, 2010 | Kodak i40 Path-Through Scanner
Error 8 in scanner i40
Error 8 = Face up light check failure.
Check Top Lamp is lighting up and not Flickering.
Check connections to Ballast (Inverter) and Lamp.
Jun 30, 2009 | Kodak i40 Path-Through Scanner
Check kds.log -this is my massage error when i press scan option at canner kodak i 260 "check KDS log" messge error appears when scan option chosen on i40 Kodak Scanner.
Try Calibration routine. If it fails check optics are clean and not scratched. If it still fails change the lamps.The KDS.log is encrypted and can only be accessed via a license key. This is only Available to Kodak reps or through RTS ltd service calls.
WWW.Responsets.co.uk.
Mar 25, 2009 | Kodak i40 Path-Through Scanner
Kodak i40 Scanner - paper jamming
First clean with a damp cloth, then try Isopropyl Alcohol. Dont use solvents. Check if papers are sticky. Stapled papers are 'sticky' even after removing staples. loosen them if required. Notmally rollers last 200,000 to 250,000 scans
S. Mohan, Chennai, India
Mar 17, 2009 | Kodak i40 Path-Through Scanner
Kodak i40 Front loading scan
Try downloading the latest Firmware for the Kodak i40 Scanner at the following Kodak.com page: http://graphics.kodak.com/docimaging/US/en/Products/Document_Scanners/Desktop/i40_Scanner/Support/Drivers_And_Downloads/i30_and_i40_Scanner_Firmware/index.htm
Follow the instructions carefully, and make sure that the scanner and the PC DO NOT turn off while doing the Firmware update. I recomend connecting both to a UPS with a known good battery while doing this upgrade.
This should install the latest features including the one that enables front feed.
Otaron
Jun 02, 2008 | Kodak i40 Path-Through Scanner
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
Kodak I-40 Scanner
8 Face up light check failure is the only code listed, not "88" for this model.
If code 8, the top lamp may well be occasionally flickering. Could be the Lamp or the Inverter (Ballast) check connections to lamp.
Jan 12, 2007 | Kodak i40 Path-Through Scanner
Kodak i40 Path-Through Scanner Logo
483 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
