My big screen tv has device button on it as well as the controller but when i try to press device to chng it to the dvd player after a few seconds of pressing device the tv shuts off and the timmer light blinks. Then i have to shut down all power to tv for 5 minutes then turn on and wait for 1 minute for the timer light to stop blinking before i can turn tv back on.
Press the "On" button on the remote control to turn on the DVD player.
Press the "Setup" button on the remote control.
Press the following buttons in this precise order: 9210.
Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD
Player Combo press DVD/VCR once. After programming a VCR Combo device,
you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a
DVD Combo device, you will be able to control channel selection, volume, and
DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and
then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 to 5, trying each code for your
brand until you find one that works. If it still doesn't work, try Searching
For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when
the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are
searching for.
Thank You
