Question about iRiver iHP-120 MP3 Player
Cannot recharge iRiver iHP-120 battery
My 4-year old iHP-120 no longer charges. For a while, I could get it to charge by jiggling the charger cord and/or trying multiple outlets. The green light would go on, and the battery would charge. Now, the green light does not go on and the battery does not charge. Since this player does not have a removable battery, are there any solutions? Is the problem the player or the recharger/AC adapter? Thanks.
Re: Cannot recharge iRiver iHP-120 battery
Battery replacement directions are advaliable from
Posted on Oct 08, 2007
0 characters
3 Points
Iriver B30 low battery and will not charge
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | iRiver B30 (8 GB) Digital Media Player
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
Iriver iHP-120
You can get a replecement on Ebay or at Maplins the spec is
In: 100-240V~50-60Hz 360mA
Out: 5V~2A
be careful I once fried an IHP-120 by using the wrong charger. I replaced the battery but taht wasn't the issue. I had it replaced with a IHP-140 and now my old charger has gone too. I got a replacement through the company I bought it from but they have none left.
Nov 08, 2007 | iRiver iHP-120 MP3 Player
Recharging of iriver-120 mp3 player
I got a battery box where 3 AA fit in Maplin. I bought just in case I run out of battery in a camping hike. It works. However, Maplin is a good place to get a replacement
Input: 100-240V~50-60Hz 360mA
Output: 5V~2A
Nov 03, 2007 | iRiver iHP-120 MP3 Player
Iriver iHP-140 will no longer switch on
I just reccommended a company called avsense you can find there info on the iriver website i sent mine with a wont power up and a bad headphone jack 67 dollars later its perfect again !!!! there adress is 4038clipper ct freemont ca 94538 there phone # is 1-510-445-0188
Sep 03, 2007 | iRiver iHP-120 MP3 Player
Iriver PMP-120 will not turn on
try connecting it to ur computer or restarting it
Sep 24, 2006 | iRiver PMP-120 Digital Media Player
IRiver iHP-140
Open the player and test for battery's voltage. In case of a low voltage measurement,you should replace the battery.I don't want to be cruel with you but, maybe that the player power circuit was damaged as well,and in this case it should be repaired by a certified technician (I realy hope for you that this is not the situation). Good luck !!!
May 23, 2006 | iRiver iHP-140 MP3 Player
iRiver iHP-120 MP3 Player Logo
300 people viewed this question
Top iRiver MP3 & Digital Media Players Experts
Steven Wander
Steven Wander
Are you an iRiver MP3 and Digital Media Player Expert? Answer questions, earn points and help others
